Question about Honeywell 5804 Ademco Wireless Security watch
I installed a new battery in a : Honeywell\Ademo
I installed a new battery in a : HoneywellAdemo 300 home alarm system. Now that I have a fresh battery I need the code to reset the unit. I am no longer under contract with the service comapany, and they will not service a non member.
  • 677 Answers
Honeywell Ademco alarm systems are security alarms for residential buildings. When the alarm system is installed, the homeowner is given a system master code that enables users to access the different options available on the alarm system. You can change the system master code if you are uncomfortable knowing that the installer knows the code, or if you want someone who knows the code to not have access to the features in the alarm system.
  1. Step 1 Enter the system master code using the numbers on the keypad. The system master code is the code you were given when the alarm system was installed.
  2. Step 2 Press the "8" button and then "0" and "2." The "8" is the code button and is used to set different settings for the alarm system. The "0" and "2" is the code used to reset the system master code.
  3. Step 3 Enter the new system master code twice using the keypad. The system master code must be four numbers long.
How to Reset a Home Alarm System
Things You'll Need:
  • Needle-nosed pliers for battery disconnect
One in every four U.S. homes has a security alarm. Alarm distributors often provide free installation to homeowners with a monitoring and service commitment. When that commitment ends, however, many homeowners resort to using their alarm system locally--not tied to a central monitoring or police/fire alert service.
Homeowners occasionally find it necessary to reset their home alarm system. This can occur for any number of reasons, including a power outage or brownout; the need to change the alarm unit backup battery; or purchase of a new home with no knowledge of the password. When they contact an alarm company for help, they are often told that the company will not reset their system unless they purchase a service or monitoring contract, an often costly proposition.
Posted on Jul 05, 2010
  • ikechukwu joshua
    ikechukwu joshua Jul 05, 2010
    1. Alarm companies make their money by providing monthly monitoring
    services for homeowners. As a result, they are not usually interested
    in helping out a homeowner who has no intention of buying their
    services. There are companies that will help homeowners, however, as
    well as other resources available via the Internet. The first step is
    to gather basic information regarding the system make, model number and
    serial number. These are most often found on the master control panel,
    which is a central processing unit for a home alarm system. This panel
    is usually located in the basement, garage or closet, and often is
    locked. This panel should contain detailed information about your
    alarm system on the inside cover.
    2.Check the manufacturer's website for installer instructions. It is
    usually easy to locate basic system operation manuals written for the
    homeowner. Homeowner alarm system manuals, however, do not typically
    include reset instructions. Installation manuals can sometimes be found
    online for a given system. Use a search engine for the specific
    system model number to find any web resources that may be helpful for a
    given system.
    3.Check out do-it-yourself alarm support sites (see References below).
    Other homeowners may post information helpful in resetting a particular
    type of alarm system.
  • ikechukwu joshua
    Generic Alarm Reset Instructions
    Locate the power source to the Main Control
    Panel. Disconnect the power. If the panel is hard-wired, this will
    require cutting off the circuit breaker at the house electrical panel
    board.
    Disconnect the backup battery in the Main Control Panel. Pull both
    leads from the battery. Take care: Battery leads are easily broken.
    Leave power off for a minimum of five minutes.
    Reconnect the battery leads. With the help of a friend, power up the
    system. While one person activates the power, the second should be at
    the alarm system control panel.
    At the alarm system control panel, press the * (star) and # (pound) keys
    at the same time. Hold them for approximately five seconds while the
    system is powering up.
    Key in the installer code. This varies by manufacturer. Ademco common
    installer codes are (4+1+1+2), followed by 8+0+0. This sequence will
    put the user in the data fields, where password information can be
    reset. For Ademco model alarms, *97 resets all alarm features to
    factory defaults. Other systems should enable the user to scroll
    through a series of screens to reset alarm system features.
    Tips & Warnings
    • Some
      alarm installer manuals are available online (search manufacturer or
      distributor websites).
    • Take
      care when disconnecting the alarm battery (terminal tab is easily
      broken).
  • Step 1
    Locate the power source to the Main Control Panel.
    Disconnect the power. If the panel is hard-wired, this will require
    cutting off the circuit breaker at the house electrical panel board.
  • Step 2
    Pull both leads from the battery. Take care: Battery leads are easily
    broken.
  • Step 3
  • Step 4
    power up the system. While one person activates the power, the second
    should be at the alarm system control panel.
  • Step 5
    (pound) keys at the same time. Hold them for approximately five seconds
    while the system is powering up.
  • Step 6
    Ademco common installer codes are (4+1+1+2), followed by 8+0+0. This
    sequence will put the user in the data fields, where password
    information can be reset. For Ademco model alarms, *97 resets all alarm
    features to factory defaults. Other systems should enable the user to
    scroll through a series of screens to reset alarm system features.
  • Read more: How
    to Reset a Home Alarm System | eHow.com
    http://www.ehow.com/how_4672355_reset-ho...
Honeywell Ademco alarm panel reads Chime BAT 11
The answer above is incorrect. If the back up battery was low it says, "bat" on the screen and that's it. Since the "11" is being displayed, zone #11 on your wireless system as a low battery.
Jan 07, 2014 | Honeywell 5804 Ademco Wireless Security...
Ac/lb light keeps flashing and home alarm beeps every 5 minutes or so and i cant get the light to go off
What model is your alarm system? The maker (Honeywell, Ademco, DSC, Napco, Caddx, ITI, GE, Moose, Morse, etc etc etc) and model number is usually inside the door of the control panel cabinet on a diagram. Numbers printed at the top of the control panel (NOT the keypad) circuit board is also helpful.
Sep 22, 2010 | Honeywell 5804 Ademco Wireless Security...
Honeywell Ademco alarm panel beeped repeatedly for about a minute and now reads, "Chime BAT." How do I fix this problem?
Find the metal box (usually beige) housing the control panel and open it. The system backup battery is inside. Take it to Battery Warehouse or similar store and buy a new one to replace it.
While you're inside the control box, read the model number of your control panel. That can be useful for future questions.
Sep 12, 2010 | Honeywell 5804 Ademco Wireless Security...
Dear Sir: I would like to acquire programming instructions that will allow me to program my home security system cell back up to my current monitoring company. The cell back up has been released by my...
Your current monitoring company would take information from you that is typically on the cell radio then upload it with any changes they need. Your new monitoring company should be able to help GL.
Jun 30, 2010 | Honeywell 5804 Ademco Wireless Security...
Setting alarm to beep when doors are opened.
If it is a honeywell product enter your code then 9
Jan 12, 2010 | Honeywell 5804 Ademco Wireless Security...
ADEMCO alarm system indicates A/C not ready. What does it mean, how to fix it?
Turn the alarm off two times. If it still indicates A/C not ready, press the * key and it will tell you what zone is open or what zone has a low battery.
Nov 22, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell Ademco 128B alarm panel
You could use a vista-key module on the polling loop without using a card reader. My question is, what will hold the door shut if the strike plate is unlocked? It sounds unclear what the client wants their system to do and or what type of system they want
Nov 08, 2009 | Honeywell 5804 Ademco Wireless Security...
Our Ademco 6160 PL3 alarm system keypad has an error message
It is located inside a tan colored metal box 12"wide by 15" tall and 4" deep; unless it is flush mounted, then only .5" deep. inside you will most likely find a 12 volt 4 or 5 or 7 amp hour battery. Note; the door may have a lock on it. I have found the key on top of the box, in the lock, and unlocked. The box could be located anywhere but, many times in closets, utility rooms, garages, crawl spaces, etc.
Nov 01, 2009 | Honeywell 5804 Ademco Wireless Security...
How can we use the Honeywell alarm LYNXR series without the service if we dont know the installer code. Where would the code be found anyway?Thanks
you have get into programming by disconnecting the power then reapplying it (battery first) within30 seconds press1and 3 ( same time ) until you see 20 flashing. press #20 and the installer code will be displayed one number at a time. If you want to change it press *20and whatever 4 digit code you want the installer code to be. Next Press *99 The system will reset and come out of programming
Oct 22, 2009 | Honeywell 5804 Ademco Wireless Security...
Honeywell 5804 Ademco Wireless Security watch Logo
1,431 people viewed this question
Top Honeywell Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Honeywell Watch Expert? Answer questions, earn points and help others
