Question about Jura Capresso Impressa S8 Coffee Maker, Espresso Machine
How do you fix the malfung s error in jura s8? I
How do you fix the malfung s error in jura s8? I turn off, wait
, then back on. This is only a temporary solution. I've stuck my hand in the try opening and toggled the flap tried reaching w/ fingers up where the puck drops out, got a few grinds out, but no fix. I'm about ready to disassemble the unit to get a better view of the mechanics of where all the grinding/straining noise is coming from and so far have not read any true solution online.
  • 148 Answers
5 Suggested Answers
  • 46 Answers
SOURCE: jura impressa S70
its a grinder group fault , the seal on the internal group head (the part that compresses the ground before brewing) has stuck or gone dry from lack of use. if u gain access to the internal of the machine( may need a special tool, oval head srews) grease with food grade lube, the red/orange seal on the long 45 degree cylinder inside. u can manually turn the gear by hand once inside. If still a problem check the motor that drives the same unit.
Posted on Feb 09, 2008
SOURCE: Jura Impressa E fails to dispense, then gives "open tap" message
I had the same problem, when I called their very helpful customer service, I was given these directions.
Take out the tray.
Inside the machine you can now see a flap hanging from the top.
Reach behind the flap, and you should feel a round object/filter. It has a little dimple sticking out in the middle.
Wipe the filter with a paper towel.
Put the machine back together, and voila you got your coffee brewing again.
Posted on Jul 07, 2009
SOURCE: Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Posted on Aug 14, 2009
Testimonial: "Grinder is turning but old bean oil is clogging it. Stirring beans on next brewing after drying the grinder was also customer services recommendation"
  • 1711 Answers
SOURCE: I have a Jura-Capresso Model
You can find some detail procedure in this tip below
Try it since it have help some other with same problem.
Posted on Aug 23, 2010
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
Jura impressa s8, the display shows" please wait" and doesn't switch to the Coffee Ready.
This error is because:
1- Flow meter is blocked & not sending signal of water flow.
2- Entire hydraulic system is filled with Calcium deposits and slowed down flow of water.
1- Open the machine and manually clean flow meter. It is located between the water tank & the pump.
2- Follow this by manually descaling the machine. Seelink. Do not use automatic descaling method suggested by Jura.
Stop using Filter cartridges as the machine reminders for descaling are silenced by use of filters. Services Unlimited Inc Parts Guru Since 1988
Apr 22, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
How to fix malfunc.8 of the jura impressa s90
Error 8 is a general error for not being in sync. There is a encoder disk that tracks where all the mechanical pieces are during the process. When they are not where they are supposed to be its an Error 8. This can be caused by a jamb, being dirty, faulty sensor... lots of stuff. Probably means your unit needs to be disassembled and cleaned.
The quick way to clear this is pulling the cord out of the wall and wait a few seconds and plug it back it. This will cause everything to reset and usually clears the error... until you can clean it.
If you need help, parts guru has videos on youtube, parts and will rebuild you brew group for you. I have repaired mine 2x.
Nov 09, 2013 | Coffee Makers & Espresso Machines
I have a Jura Impressa F50 model. I have the indication Error 8. I can insert the tray and the dump box but then the machine makes a loud noise and finally indicates error 8. I can remove the tray and...
This is the 2nd time in a month since I've had this machine that I had to call support for the same problem. An easy fix! I was instructed to remove the whole 'drawer assembly' and remove the grounds bucket. Insert the assembly without the bucket. Wait a minute, take it out again and replace the bucket. Then you're ready to go. Hope this helps.
Dec 16, 2010 | Jura Capresso Impressa F9 Espresso Machine
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
Sep 13, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Jura Capresso Impressa S8 Coffee Maker, Espresso Machine Logo
603 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
