Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer loses cooling ability and everything thaws
Twice in the past two weeks, we wake up to find things melting in the freezer. Power has not gone out. First time we unplugged it and then restarted it and worked for a few days, but happened again last night. Sounds like the motor is working. Took off the cardboard backing to vacuum small amount of dust underneath, but couldn't see any problems.
    President:
  • 2,468 Answers
Open up the freezer panel inside the freezer compartment back wall area and check the evaporator coil,if it has a heavy amount of ice on it you need to use a hair dryer to melt this build-up,then you need to test the defrost heater element below this to see if its bad,if not then the defrost heater control be it timed or adaptive could be bad,
Posted on Jul 05, 2010
Freezing up in duct system frig part
Have you checked the heater/defroster element within the freezer? It may be related. When mine failed I was doing the defrosting with a hair blower. Over time (several days) the frost would build up on the freezer coils and the air couldn't flow as it should....so the thermostat wasn't getting cooled enough and it relayed the information to the cooling system, causing the frige to run all the time. Since it was clogged with frost, the frige was constantly trying to cool itself and the frost problem would get so bad that things in the freezer began to melt due to a lack of cold air circulation. After the heater/defroster element was replaced, frost would melt during the defrost cycle (as it should) and airflow/circulation was restored, allowing the thermostat to be cooled properly. Then the freezer coil was able to 'rest' when it should instead of constantly freezing to meet the demand for cold air in the frige. Hope this makes sense...and helps solve your issue.
Apr 11, 2014 | Kenmore Refrigerators
My ice cream is melting and things have started to thaw
Turn the t'stat up to 9. You want to save the meat and ice cream. It sounds like you may be losing freon. Get it looked at soon so you won't come home and find meat soft and ice milk.
Mar 06, 2013 | Whirlpool EV160NZTQ Upright Freezers
Today morning food in the freezer was thawed & things were melting & food in the refrigerator was frozen
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidiare upright freezer has just stopped cooling
I was hoping it would be something like a cracked door seal, or a faulty thermostat, etc., but after reading the rest of your info, I've concluded the likely cause is a slow leak in the refridgerant line(s). I've seen many of these fairly new upright freezers with this problem.
Finding the leak is easy for a service tech to find, but the cost of the service tech isn't cheap and unfortunately, the repair cost will probably exceed the cost of a new freezer, but you can try to call a repair tech and see if they can give you a rough estimate over the phone or if they think it's worth fixing, etc.
My advice is to replace it. The cost of food you've lost has probably exceeded the price of a new freezer - and you've had this happen twice now. These days it seems that some appliances are being designed and built as "throw aways" due to the high repair cost.
Wished I had some better news for you, but unless you've got all the specialty tools; (charging gauges, vaccum pump, Freon, etc.) needed to do the repair yourself, along with the technical knowledge, it's likely not worth having the repair service contracted. Best Regards.
Jul 30, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
GE Side by Side refrigerator/freezer Evaporator keeps freezing up
Sounds like the auto-defrost timer has gone bad. In many cases, that is the cause. Check with GE service.
Sep 04, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire professional series. Feels cool inside but the air is not circulating and everything is starting to thaw out, ice is melting.
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Jul 12, 2008 | Refrigerators
Freezer is only cool, everything melting
  • possible causes:
Jun 24, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
91 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
