Question about Sony (RMT-811) Remote Control
How do I make the remote give me a full screen instead of a panoramic view
Can I only view a panoramic series if I print out the photos? No way to view it digitally on computer? Thanks, rj
You can view panoramic pictures on the computer. If your panoramic pictures have not been combined, their is software that can do that for you. Here is a free panorama stitching software from microsoft that you can try:
http://research.microsoft.com/en-us/um/redmond/groups/ivm/ICE/
Jul 07, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
When watching movies or football games the text/score is often off the edges of the screen. I have tried changing with the remote with the options cinema, panormaic 1, panoramic 2, full and zoom and 4:3...
The change actually has to be made with your cable/satellite service's remote control. On the cable remote you should have a #hd zoom button. On the satellite remote it may be format, aspect, or a setting within the menu. The cable/satellite box's menu will also have a setup section where you make sure the resolution is 16:9 1080i fixed. Make sure to disable the 4:3 override as well. Then you use the button on your tv remote to further adjust it with cinema, panoramic, full, or zoom.
May 09, 2011 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Hi. I have a LG LD 460. How can i view movie video using full screen of 42 inch from the USB. what i mean is what is the size of the video file in width x height which when run from usb will use...
Hi!
you can convert the video to one of this sizes (1920x1080 or 1280x720) and it must fit exactly to your screen.
If the video is not panoramic (16:9 or 16:10), you may have to crop it to fit on the given screen sizes.
Hope this helps.
Mar 05, 2011 | Video Cameras
Help? Magnification on an Acer laptop.
You pressed the Alt Gr button along with the down arrow, Try, the same but use the UP arrow instead, usually the "Opposite" last key, usually reverses the action, up, down, left, right etc...
Mar 01, 2010 | Acer Aspire One PC Notebook
Picture is cut off at top and bottom
I had the same problem with my westinghouse 47 inch HDTV. It turned out that someone had inadvertently hit the "format" key on my satellite (Direct TV) TV remote controller. If you have satellite TV you might want to check this out. I set it back to the previous setting and I get the entire screen. Hope this helps someone.
Oct 20, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 37'' TV
This is normal.
Oct 21, 2007 | Vizio L37 Television
Panoramic pictures??
A panoramic photo on 35mm film is just cutting off the top and bottom. even if you can't set the camera that way, you can ask your local photo store to print any shot that way for you. Usually 2x the price of 4x6.
Sep 13, 2007 | Minolta Freedom Zoom 115 QD 35mm Point and...
Distortions in sides
Sounds like you might be in the panoramic display mode... check your remote for a button labelled "WIDE" - it's on the left side just below the "GUIDE" button. Hitting WIDE will cycle through the various viewing modes (normal, zoom and panoramic).
Aug 23, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
70 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
