Question about Yamaha 12V Air Pump
My1998 yamaha xl1200 is a repo and cannot start
    Genius:
  • 1,416 Answers
what you need to fix up to solve this problem is to check on the power supply connected to the started (switch unit on and off ) and make sure that the battery is in good condition
because it is always the problem of the starter trace the wire down to the power unit to see if all wire are in there proper position if not then you will have to release any that has loose it position with care please you will have to note how you are removing the old wire when replacing the new one to avoid wrong connection
thank you and thanks for using fixya.
Posted on Jul 05, 2010
Xl1200 starts runs fine for a short time engine bogs downs and or dies start right up and runs fine for short time and bogs down
Check for venting problems in the fuel tank. Is there a small screw on the filler cap that has to be unscrewed to let the air in when running
Apr 01, 2013 | Yamaha Boating
My1998 explorer just quit it won't start i got new
The 98 explorer is equipped with a power surge system to protect internal vehicle wiring, what this means is that if there is a short in the vehicles wiring the alternator will disengage. A way to tell if it is faulty wiring is to pull all the fuses out of the fuse block and try to start it if the engine turns over the problem is internal wiring. If not then you have to put all the fuses back.
Jan 31, 2013 | Cars & Trucks
Just changed the starter motor on my xl1200 limited 1999 and it's now making a grinding noise what should I do ?
U may have the wrong starter or it requires shims ( spacers) to adjust proper clearence.did u possibly drop or not see them when takin out?
Jan 09, 2013 | Yamaha Jet Ski Pwc Cover For Waverunner...
Yamaha xl1200 waverunner losses power after it is warmed up.
Hi, most likely cause and the easiest to check is exhaust leaking in the engine compartment. Run it without the seat fitted for the same time frame and if it fixes your problem you are looking for an exhaust leak. Regards Phil.
Aug 23, 2012 | Yamaha Boating
My1998 1100 Yamaha virago with cobra pipes cracks and backfires
Since fitting the aftermarket exhaust system .have the jets been replaced tosuit the system?.
Jun 21, 2012 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
Not turning over engine
Please re post this in the correct area as this is the Air Conditioner area.
Jun 16, 2012 | 1998 Yamaha-2003 Waveruner Ls2000 Xl1200...
Where is the tool kit on my 1998 royal star
Hi, Anonymous sorry you can't find the first and best tool you ever bought for your Yamaha despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.yamahaventure.nl/pdf/servicemanualxvz13tf.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/1998/Lit-11626-11-17_320.pdf
Yamaha XVZ 1300 Royal Star 1998
Jan 11, 2012 | 1998 Yamaha Royal Star XVZ 1300 A
I have a 2000 Yamaha XL1200 waverunner. When I went to start it, the existing battery was weak. So, I put in a new battery and now it won't even try to start.
my 1998 xl 1200 has this thing it the batter is changed or if it sits for awhile you have to hit mode then something that says code should pop up on the screen then hit a b c a and then it should be able to start. but your code may be different
Jun 20, 2010 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
111 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
