Question about Sharp YO-P20H Handheld
Just put new batteries in and screen isn't showing clearly.. What do i need to do?
    Scholar:
  • 55 Answers
Have you done charging the battery initially for 6hrs. The best way to get maximum efficiency & output from a battery is to charge the battery initially for 6hrs (evenif the full battery notification is shown), Then drain the battery almost full and repeat the procedure three times.
Don't you bought the original Battery? Please check that too.
Regards
Vineeth K.
Posted on Jul 05, 2010
My watch face shows many of the "screens" all at
it can be done by moisture so put it in the heat to remove the moistuere or put it the rice bag for 5 months so the moisture can be remove
Aug 11, 2011 | Polar F11 Heart Rate Monitor
Even after putting a new fully charged battery camera shows battery empty
The reason you are still getting this error despite the fact that you've placed a new fully charged battery means that the battery is not compatible with the camera. The fact that it states this is because the battery isn't capable of handling the Olympus camera. I would suggest for you to buy a recommended battery pack by Olympus, or a rechargeable battery pack to avoid these errors.
Jun 30, 2011 | Olympus Cameras
Isn't starting. battery isn't getting a charge. bike starts once the battery is charged
Your battery MOST LIKELY has lost some of the battery cells, which will cause it to get a partial charge which will show it as a FULL charge when in fact it isn't getting a full charge. You should try taking it to get the battery tested and they can tell you if it needs to be replaced. I would guess they are going to replace it for you. A new battery should run around $90 for a motorcycle. Let me know if this helps you out. Jeff from fixya
Jun 11, 2011 | 2007 Hyosung GT650R TTC
How can I tell if the blue battery charger is working? It was warm when I unplugged the battery....I also want to know how to check the battery to see if it is good.....It did work a little the last time I...
check the battery with a multimeter and see if its showing 12 volts or more, if its not showing any volts the connectors on the battery under the plastic housing have probably come disconnected, you'll then have to pry off one side of the battery and reconnect them, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
May 30, 2011 | Peg Perego - 6 Volt Battery Charger...
The battery does not charge, its a new battery.what do i look for?
if its a new battery it could be as simple as it wasn't charged when you purchased it, If it was charged and your mower isn't charging it, the power source to the battery from the mowers motor isn't working properly,, not knowing if its a 12 or 6 volt system you need to check the battery ,, see which one it is,, using a multimetter ( if its 12v ) check the battery after you charge it with an outside source ( battery charger) you would have a reading of 12-12.5 volts on a normal check,, then start the mower, and check the battery as its running,, you should get a reading of 13-13.5 volts minimum, if your not, the alternator or magneto isn't working properly, if you do show the increased voltage at the battery connections, then you need to clean the contacts since the charge isn't reaching the actual battery
May 24, 2011 | Garden
My batterys not charging
May 06, 2011 | Peg Perego 12 V Slim Battery Iakb0014
John deere turf tractor has no power, recharged battery for 24 hours but still zero power. Checked all connections, everything is connected. Tractor is approximately 6 months old
Apr 26, 2011 | Peg Perego IGOR0040 John Deere Turf...
My son has a 700 twin sportsman peg-perego four wheeler. Weve charged thae battery . But when we hook it up the four wheeler will only go really slow as if the battery is dying or dead. Does it need a new...
check the battery with a multimeter and see if its showing 12 volts or more, if it is showing volts but not 12 or more then put it on the charger for about 8 hours, then check the battery again if it still hasn't went up check the voltage of the charger with the multimeter and make sure that the charger is putting out 13.8 volts or more, iif it isn't then you need a new charger, if it is then you need a new battery
Nov 30, 2010 | Peg Perego 12v Battery
Sharp YO-P20H Handheld Logo
104 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
