Question about LG enV3 VX9200 Cell Phone
I accidently pressed the CLR button and it asked me to speak a command. So i called my home phone then hung up. since then my internal screen has only half screen with sound lines on bottom half and i can't dial out my home phone
  • 342 Answers
This is due to the enabling the settings of speak command.you have to keep it disable,then you can dial.
Posted on Jul 05, 2010
Need help with my samsung note 4 phone.PLEASE
Press and hold Home button and Volume Up button which forces a reboot.
Jul 21, 2016 | Samsung Galaxy Note 4 SM-N910H Black...
I want to restart my phone to its factory settings but i can not because i forgot the lock code of my cellphone. is there anyway or any applications i might use to remove the lock code? thanks.
Unfortunately the original password will be needed to restart any security locked cell phone to it's factory settings. I suggest you speak with a customer service representative at your nearest service provider location to fix this issue.
May 03, 2011 | Cell Phones
My iphone went dead. I hung up from a call and then went to use it again - dead. Plugged in for 1/2 hour and still no juice. Is there a reset button?
Charge your iPhone overnight. If that does not work, try the following resets:
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least ten seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
  4. More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 17, 2011 | Apple iPhone Smartphone
How to end a call by voice command
To avoid the possibility of hanging up on the person you are speaking to by accidently giving the device a command to end a call by voice, there is no way to end a call this way. To end a call you must simply tap the MFB button one time or wait for the other party to hang up first.
Rylan
Nov 18, 2009 | Blueant V1 Bluetooth Headset
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Master Reset
the OPCODe can master reset the phone. I screwed up my phone by trying to change the theme and evry time i pressed menu the phone restarted. However, i found a post on another site that read...
For me, Motokit, PTS, and the reset of the tools could not reset my phone. Here's how I reset my phone with just the phone keboard.
This will reset all your menus. On my Verizon Razr V3m phone, my contact and my picture gallery were not affected. (Make sure you key the command in exactly. 18*1 is Master Clear, and you don't want do to that.
From your phone, enter this sequence to go into OPCODE mode fairly quickly:
Press CLR then
048263*
This puts you in OPCODE mode, where you can enter special commands. Be CAREFUL here.
Enter a the code for a Master Reset command:
18*0
Press the middle navigation button.
Wait. The screen should show "SUCCESS" after a few seconds.
Push the LEFT soft key (back). You'll be back at the OPCODE screen.
Push the RIGHT soft key (options). Push this button again to select Cancel Entry (the only option).
This gets you out of OPCODE and back to where you started. You might have to push CLR a few times to clear the number you entered to get into OPCODE mode.
It was really helpful
Aug 16, 2008 | Motorola Mobility RAZR V3m Cellular Phone
I dropped my slvr and now the screen is white - can I retsore the screen?
to do a master reset blind press the red button a few times to make sure you are at the home screen. now press the center button once, press 8 then 5 press up twice then the center button once now enter your 6 digit security code and then press the center button twice. that should do a master reset on your phone. If that doesn't work then your screen is destroyed. If you don't want to spent money on a new phone you can always use the voice dialing button on the right side of the phone located right under the charging terminal. press it once then give a command (EX. "Call Joe smith") the phone should confirm the command, then say yes or no
Aug 06, 2008 | Motorola Mobility SLVR L7 Cellular Phone
My oricom wireless home phone is locked
press down on the # key for a couple of seconds as this also unlocks the phone.(the key symbol isn't very clear but it is there.
plus you can find user manuals for most phones online.
Oct 11, 2007 | Lands Phones
LG enV3 VX9200 Cell Phone Logo
103 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
