I have 2005 chevy silverado 1500 2wd. My air conditioner runs fine the only problem is that no air is coming out of the dashboard Vents. How do i fix it.
    President:
  • 2,468 Answers
You need to access the air diverter motor that channels the air from the floor to the defroster vents and to the dash vents,its either defective or theres no power to it,also it can become gummed up and not move from dirt and debris dust in the motor shaft and can no longer over power this to move when you select to do that,its usually located behind the glove box on the passenger side and can be powered by either electric 12 volts or vacuum from the engine,but most now days are of the electric variety
Posted on Jul 05, 2010
Heater vents
Damper is not opening all the way or not at all!
Nov 29, 2013 | Chevrolet 1999 Chevy Silverado
2005 chevy silverado steam through air vents
Probably fog.
Either the ac is not draining onto the ground, or the system is cutting on and off too much, or its not letting in enough fresh air. The fog would be from moisture inside the hvac box.
Jul 17, 2013 | Cars & Trucks
What to do when air conditioning vents on 2005 chevrolet silverado1500/v6 ?
It is all electronic these days an electric motor is controled by the selector on the dash. Remove the dash surround: gear selector in 1st engine off, tile steering wheel down, push down FIRMLY on the top of surround and pull towards you and off it comes. Remove the two screws that hold the heater/air cond. control in, there are 4 plastic clips as backup release them and gently remove the control, inspect for loose connectors (there are 2) it helps to run the blower to see if you have found the problem- I did.
Jul 27, 2012 | 2005 Chevrolet Silverado
2003 Chevy Silverado ac bashboard vent not blowing.
There are controls in your car where you can control the flow of air to certain parts of your car. Make sure that you have it turned to where it blows out of all of the vents and then the air should come out of the dashboard. If this continues then there might be a ventilation hose that has been disconnected and is not getting air to that part but the other hoses are still connected.
May 25, 2011 | 2003 Chevrolet Silverado 1500
Unable to move air output to front vents or floor on my 2005 Chevy Silverado 1500HD. It is stuck on defrost. AC and blower working fine
ur acuator doors are bad usually happens when battery goes bad or is unhooked google sparkys answers and theres how to and pictures thats how i fixed my 03 1500hd also until i found out how to fix id go to the fuse box under hood while truck was on and pull ac fuse wait 10 sec replace and it usually blow out front vents until i turned truck off if u recently had battery go bad or unhooked look at recalibration on sparkys answers its simple and might be all u need
Apr 24, 2011 | 2005 Chevrolet Silverado 1500HD
My Defrost doesn't work
Check to see if the duct hose to the defroster vents has come loose. If air is blowing out under the dash when you have the control set to defrost, then this is likely.
Dec 13, 2009 | 2003 Chevrolet Silverado 1500
Air only blows outthe defroster vents on top of the dash
unhook battery, rehook battery, turn key on, ..............wait 2 minutes, then start truck and ck a/c. sometimes it works, if not, it will need to be checked by a shop .
Sep 18, 2009 | 2005 Chevrolet Silverado
2003 chevy silverado air does not blow through vents. Condenser works. Pipes are cold. Fan works. Modular (next to fan) repalced to get fan to work. Heater air conditioner controls under radio replaced....
The air vents are control by vacuum line and or linkage.
Listen for hiss or feel for vacuum leak under the dash,
Feel for broken linkage(s) that are close to the vents.
WORK BACKWARD if you have small hands to feel out where is the missing link.
Jul 15, 2009 | 2003 Chevrolet Silverado 1500
Heating & Cooling Logo
148 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
