Question about Hyundai Televison & Video
The park/handbrake comes on in the dashboard when I turn left around a corner - I have to put my foot on the brake for the lights in the dashboard to go away - I have no idea if the park/handbrake is actually coming as I can't see the back of my car when I am driving
    Brigadier General:
  • 7,191 Answers
Kindly submit the question under the Hyundai Excel section on the website by clicking here so that the top automobile experts can view and provide a solution to the problem.
Thanks for using FixYa
Posted on Jul 05, 2010
I have a 2005 renault grand scenic that recently went in the garage for work and has come out with the 'parking brake failure' message on the dashboard. The handbrake is electric and is working perfectly...
A renault tech told me how to reset the electronic parking brake on my grand scenic without going to dealer, this works if you have had to pull the yellow emergency handle in rear which i have had to do this week.
Turn your ignition on without starting engine, have drivers door open and press lock button on keycard
put keycard in reader and press start button for 5 seconds.
pull large part of manual handbrake handle and push small button with red light without letting go of larger handle and you should hear the handbrake motor reset!
That should be it!
Oct 05, 2014 | 2005 Renault Grand Scenic
How to adjust parking brake on 1993 chevy lumina ?
  • Adjustments
  1. Apply service brake pedal three times with a force of approximately 175 lbs.
  2. Fully apply and release parking brake three times. Full application may require two pedal strokes.
  3. Raise and support vehicle, then mark relationship between wheel and axle flange.
  4. Check parking brake pedal assembly for full release as follows:
    1. Turn ignition switch to On position.
    2. If ``Brake\'\' lamp is illuminated, operate manual brake release and pull downward on front parking brake cable to remove slack from pedal assembly.
  1. Remove rear wheel and tire assemblies, then install two lug nuts to retain each rotor assembly.
  2. If two parking brake levers on both calipers are not against lever stops on caliper housings, check for binding in rear cables and/or loosen cables at adjuster until both left and right levers are against their stops.
  3. Tighten parking brake cable at adjuster until either the left or right lever begins to move off the stop, then loosen adjustment until lever moves back barely touching stop.
  4. Operate parking brake several times to check adjustments. A firm pedal feel should be obtained by pumping pedal two full strokes and rear wheels should not rotate forward when parking brake is fully applied.
  5. Install wheel and tire assemblies, aligning marks made in step 3.
Sep 06, 2014 | Cars & Trucks
My suzuki Baleno the handbrake light comes on going around corners, and the check engine light comes on usually when I speed up
low brake fluid, what year/ lost the operators guide, ?
the light glows for 3 reasons, or 4. (depends on year)
hand brake, fluid, abs (rwal) , and brake failure front or rear
the check engine light coming on is (maybe) and engine fault
again no year, stated, but it means to scan the ECU to get the
errors. connect scan tool, press scan, bingo.,
on some years,1997 and above, it also reports, A/T errors.
tranny
Jan 18, 2014 | Suzuki Cars & Trucks
How to install a headlight switch in a 2001 chevrolet suburban
  • 1.Park the vehicle on a smooth, level surface and set the parking brake. Tilt the steering column to its lowest position.
  • Place your right foot on the brake. Put the key in the ignition and turn it to the "On" position, but do not start the truck. Shift the gear shifter to its lowest position.
    • 3
  • Grab the dashboard bezel that goes around the radio and the gauge cluster with your hands, and pull it toward you to release the clips that hold it in place. Then unplug the wiring to the headlight switch and any other accessories on the panel (which change depending on what model of Sierra you own), using your hands. Pull the bezel away from the dashboard, and put the Sierra's transmission back in "Park."
  • 4Place the dashboard bezel face down on a work surface. There are two tabs on either side of the dashboard bezel holding the headlight switch in place. Use the flat-head screwdriver to gently pry these apart one at a time, then pull the switch out of the bezel. Be careful, because depending on how brittle your dashboard is, you can break these tabs fairly easily.
  • 5Push the replacement switch into the dashboard bezel. Then put your foot on the brake again, shift the truck into the lowest gear, and reinstall the wiring to the bezel using your hands. Push the bezel onto the dashboard to secure the clips, then put the truck back in Park and turn off the ignition
  • Jun 24, 2012 | 2001 Chevrolet Suburban
    Hummer H3 airbag light wont go off
    Airbag light on in a Hummer H3 Dashboard???Here is the fix...
    Start the engine of your car, set the parking brake, hold the regular brake pedal down with your right foot. Push down the parking brakepedal to its fully-applied position with your left foot. Now while you are still holding the regular brake pedal down. Quickly release the parking brake, Pull the bottom edge of the lever, located above the parking brake pedal, with the parking brake
    symbol, directly rearward to release the parking brake. Make sure pedal snaps hard all the way back releasing the parking brake... If this doesn't work the first try, try it 3-5 times and it shall work... The airbag light will go off...
    NOTE: The parking brake pedal is located to the left of the regular brake pedal, near the driver's door.
    The parking brake lever is located above the parking brake pedal, with the parking brake symbol.
    May 28, 2012 | 2006 Hummer H3
    The wires are burnt together at the head light switch how do i change the wires also do i need to put a new head light switch i had bright lights only and was replacing the switch to try and correct the...
    Hello
    You will need to replace the switch and the connector to the switch, a new switch will not cure the problem and will quickly overheat and burn out again unless the burnt connector is also replaced. You will need to contact a local Chevy dealer for the replacement headlight connector
    To replace the switch follow these instructions:
    1. Park the truck on a level surface and set the parking brake. Place your foot on the brake then put the key in the ignition. Turn the key to the "On" position but do not start the truck.
    2. Shift the automatic shift lever to the "1" position and tilt the steering column to its lowest position using the tilt adjustment on the bottom left side of the steering column.
    3. Hold the bezel/trim around the instrument cluster and pull it towards you to release the clips holding it to the dashboard. Work your way around the bezel, pulling it as you go, until it's only connected to the dash by wiring. Unplug those wiring harnesses from the back by hand then put the gear shifter back into park. Bring the bezel to a table or counter that you can work on.
    4. Turn the bezel onto its face. Locate the headlight switch which should be on the lower right corner of the bezel. There are delicate plastic fingers that hold the switch to the dashboard. Carefully pry these away from the switch with the flat head screwdriver in one hand while pulling the switch away from the bezel with the other until it's free.
    5. Push the replacement switch into the bezel until it clicks into place. Then bring the bezel back to the SUV. Put your foot on the brake and shift the shifter into the "1" position again. Plug in the connections on the bezel then push the bezel into place on the dashboard until it clicks. Put the shifter back in park, tilt the column to its desired location and turn the ignition off.
    When replacing the connector cut one wire at a time and transfer it to the same position on the new connector, solder and shrink tube each wire, take your time. Remember one wire at a time.
    Mar 31, 2011 | 1999 Chevrolet Suburban
    Handbrake light comes on but fluid level is topped up
    When you engage the handbrake the handbrake light should come on. It has nothing to do with the fluid level.
    If it is coming on without the handbrake being applied, then you possibly have:
    1. A faulty switch. The switch activates the handbrake light.
    2. A stuck braking cable. To eliminate this place the handbrake on and attempt to back-up (reverse). It should not move with your foot off the brake. Do not put your foot on the gas (accelerator). Place your foot on the brake and disengage the the handbrake. Again with your feet neither on the gas or brake. The vehicle should move backwards.
    In all likleyhood the switch is bad. It is easily located right under the handbrake arm and easily removed and replaced.
    Let me know if this helped, or if you have any additional information, problems, or questions. Feel free to contact me at FixYa.com!
    Jan 29, 2010 | 2003 Ford Focus
    Handbrake
    They all work the same. Call it parking-brake, hand-brake or foot-brake, it is the same.
    Use your hand, or foot to apply the foot-brake, whatever is convenient for you is ok.
    Nov 24, 2009 | 2000 Chrysler Grand Voyager
    Televison & Video Logo
    23 people viewed this question
    Top Hyundai Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Jaime Hernandez
    Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
