Question about Mantis 2-Cycle Tiller
Tiller starts runs for 30 seconds then quits
If you try to till it doesn't happen engine just sputters and quits.
  • 4 Answers
Make sure the choke is off, use fresh gas and if that doesn't work it sounds like a gas problem meaning it is starving for gas or running rich. brucewo
Posted on Jul 05, 2010
1988 Pontiac Lemans Runs Rough
i can recommend to RUN scanner/computer for easy diagnostics and fix . God bless you
any components can be faulty32cbf899-f6e4-4700-9849-2f8e8911acec.jpgd28e17fa-ceac-4b84-b842-b66ec79f6c63.jpg
Jul 11, 2013 | Pontiac LeMans Cars & Trucks
We have a 1987 Ford Econoline RV ... It starts fine but will only idle for 20-30 seconds.. When we put it in drive it sputters and quits... It also sputters and quits while idling...
Can you pump the gas pedal or spray carb cleaner into the throttle body to keep it running ?
Have you checked fuel pressure with a gauge ?
Jun 29, 2013 | Cars & Trucks
Honda mini tiller cuts off when start tilling. runs great when held above ground with no load. cut off seems to be associated with the movement and shacking when tilling ground.
Hi thermo259, sounds like the high speed adjustment is lean, find the high speed screw and turn it counter clockwise 1 half turn and see if that helps. Should cure it.
Dec 10, 2010 | Honda 25cc 4-cycle Mini Tiller
Honda Tiller revs and works for 30 seconds and then shuts down.
Hello. you have some gunk in the carburator. Get a can of starter fluid or carburator cleaner aerosol and a helper. Remove the air filter and start it up. Spray a little starter fluid into the air cleaner to keep it running for three or four minutes and the problem should clear. If it does not clear the carburator will have to be disassembled, cleaned and rebuilt. j.
Jun 16, 2010 | Honda 25cc 4-cycle Mini Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Stalling under load
Check the piston rings and the valves. One of them is leaking.If you run the machine as is it will soon break down altogether...Lee
Sep 04, 2009 | Honda 25cc 4-cycle Mini Tiller
Tiller starts then quits when I start to till.
Does it run good with out a load on it or does it sound like it s spitting and sputtering? This problem sounds like it is fuel related you probably have some water in your fuel tank and carburator
Aug 17, 2009 | Mantis Tiller
I can't get it to start, it just sputters for about 10 seconds and cuts out.
If your tiller sat all winter it will need a little work. Drain all of the old fuel out of the tank, install a new spark plug and install a new air filter. Put new fuel in the tank [if you still have old fuel in your portable gas tank dump it into your car or truck so you start fresh for all of your small gas engines.
Now crank it over and it may start. If it doesn't start you need carbeurator cleaner. But an aerosol can of carb cleaner and put two squirts in the air intake [remove the new air filter and leave it off while you get the engine running]. Pull your cord, turninng the engine over and possibly starting it. If it starts, great. If not, let it sit for half hour while that carb. cleaner dissolves some of the gum built up in your carberator over the winter. Two more squirts of carb cleaner and try to start it again.
Generally it will start by now. If it doesn't start your carbeurator must be really dirty. You will have to remove it, and soak it in carb. cleaner for about three hours to clean it out.
May 27, 2009 | Mantis 2-Cycle Tiller
Troy bilt jr tiller
If you try to till too deep, this is what will happen. You have to start shallow and and gradually lower the depth on subsequent passes. That will even happen on my 'Horse' model if I try to go too deep too fast.
May 25, 2009 | Troy-Bilt Pony Garden Tiller
Mantis 2-Cycle Tiller Logo
509 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
