Question about Marantz CD5001 CD Player
When i put in a Cd it say toc reading and after that on the dispaly comes "no disk" play is not possible any more
Cd player will not play comes up with toc read, will not play any of the 3 cds.
It is possible that there could be some garbage in the main processor and to clear that out you need to unplug the unit from the wall for about 40 Min., and it will reset back to normal.
Jun 03, 2011 | Audio Players & Recorders
I have a technicks sl-pg380a audio player and it reads no disk..i tried putting in other disk everything..i took it apart and found out one of the motors wasnt working..the one that spins the disk..how can...
Be careful. The unit will attempt to verify that a disc is present BEFORE it tries to spinb the disk. If the optics are defective, this can happen. First try cleaning the lens using a cotton swab and alcohol. Try to play a clean disc. If it fails to play or read the TOC, then the optics need to be replaced.
Please keep us posted,
Dan
Aug 24, 2010 | Technics Audio Players & Recorders
Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Oct 09, 2009 | Philips CDR770 CD Recorder
Readable DVD's but not CD's
That is a faulty lens. The lens reads DVD and CD on different laser beam frequencies. To read the TOC initial track the lens must focus on the laser beam reflected by the disk. If the lens is opaque, scratched or dirty, sometimes it can focus on DVD but not on CDs or the opposite.
Try using a cleaner disk, if that does not work buy a replacement drive. Today you can get a dual layer DVD RW for less than $30.
Sep 25, 2009 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
TOC eror
The TOC error is the same error seen on computer disks, TOC is the table of content, this has to be read before the the unit will know the details of tracks etc......
If every disk inserted (not just burned discs) has this error, the laser is faulty or out of alignment. Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 01, 2009 | Kenwood Sirius KDC-MP522 CD Player
Emerson 3 disk CD player - CD spins - message
im not sure what toc read means, my cd player says that im guessing it means its loading, any ways take the d player apart an clean the lens wit a cuetip that should work, or the cds may be to scartched to read
Oct 15, 2008 | Audio Players & Recorders
TOC READ
I have the same problem... Any solutions?
Sep 21, 2008 | Emerson MS3100 3-Disc CD Changer
TOC error message
Unit displays TOC error when I inserted two new cds I purchased.
Nov 05, 2007 | Audio Players & Recorders
Won't play a cd
We have the same problem and are searching all over the web for a solution but no luck. If we find a solution we will come back and post what we found. :)
Oct 15, 2007 | Emerson MS3111M Shelf System
What does toc err mean?
TOC is table of contents. Typically if its on a recorded cd try burning a cd from antoher computer and try it, if it works its most likely that your burner or software or ccd's your using are bad. Also is it a MP3 disc your trying to play? If so then you MUST burn it as a MP3 cd. You cant just burn MP3's to a CD and it read them. If this is the case thats why you are getting the TOC error because its not writing to the CD whats on the CD on the TOC area of the disc.
Sep 14, 2007 | Kenwood KDC-MP228 CD Player
Marantz CD5001 CD Player Logo
61 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
