Question about Onkyo TX-SV727 Receiver
No sound My speakers are hooked up to the main ports. The T2 monitor is off. Muting is off. I don't have any sound
  • scupper Apr 18, 2008
    How would I know if protect mode was on? Tape monitor is off. No click when I turn on the receiver
    The display does not say protect and the standby light is not flashing.
  • 4,234 Answers
Is there an indication of protect mode on the front display? Have you checked to see if the tape monitor switch is on? Did you hear a click when you first turn on the receiver followed by a second click?
Dan
Posted on Apr 17, 2008
  • ABRsvcs Apr 18, 2008
    The lack of the click indicates that the output section is not on. This is usually becauise a problem has been detected and to prevent further internal damage or damage to the external speakers, the outputs are disabled. This is called "protect" mode. Many receivers either flash the standby light or display the word protect on the display panel. This particular unit used discrete transistors so the repair is relatively simple. If you are not familiar with electronics repair, get this to a service shop. Expect a parts cost in the range of $20-$40. Add in the local labor rate for the total repair cost.
    Dan
I have a Vx2433WM and am using it as a tv for my PS3 through hdmi connection. The audio stopped working. I tried muting and un-muting but nothings happening. How do I get my audio back??
I'd check in the control panel under sounds and see what the system thinks the output device is. Probably not the speakers. If not, change the output to your computer speakers.
Sep 28, 2011 | ViewSonic VX2835wm Monitor
I just hooked up an AOC monitor to two computers. Sound is working on one but not working on my HP Pavilion. How do I resolve that? I don't have any extra speakers.
The sound goes out of the computer to a set of speakers. If the monitor has speakers built into it, then the sound comes out of them. Each computer must have a connection to the sound card (the little green hole) to speakers. If you want sound from the second computer, unplug the sound cable from the one computer and plug it into the other one.
Sep 15, 2011 | AOC Monitor
Dennon DRA 697ci with bose 901 speakers.....just moved to new house....hooked up stereo and can only get minimal output
I assume it used to work. You need to ensure the connections to and from the active equalizer are all proper. I would think you have it in the Pre-Main loop.
It sounds to me like you have an in/out reversal at the EQ or a dead Tape Monitor selected.
Or MUTING is selected on the DRA.
Dec 25, 2010 | Denon DRA-697CI
HOOKED ALL MY SPEAKERS UP BUT SUB AND CANT GET ANY SOUND FROM FM OR TV THAT I HAVE HOOKED UP AM I MISSING SOMETHING ALSO THERE IS A LIGHT THAT SAYS SOUND MUTE BY FM
From the remote control ONLY:
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Speakers do not work. What am I not doing correctly to connect it to a dell dimension 8300 computer
Windows has a nasty habit of muting the sound. From the Speaker icon in the right bottom corner of the screen click on the speaker and unmute the sound.
Aug 28, 2010 | Mag Innovision LT765b 17" Flat Panel LCD...
Hi, i have a nad c325 bee amp and i have a problem with hooking up speakers. I have just the tiniest amount of sound coming out so there's some signal there. I have tried different speakers so i know its...
Before you continue, turn the volume DOWN. If you can't hear it at mid-volume there's no sense in spinning the volume knob higher. You'll only endanger your ears and speakers if you suddenly resolve the switch or whatever is the problem.
Are all sources acting the same?
Check these things (from the manual):
Tape Monitor selected?
Muting?
Headphones inserted?
Jumpers missing between Pre-Out / Main In?
BTW: the manual is available at retrevo.com
Apr 06, 2010 | NAD C325BEE Amplifier
Starlogic monitor speakers don't work
do you have a cable hooked into the audio port on the back of the monitor? this will go to the audio out on the back of the desktop box. let me know
Jan 26, 2009 | Star Logic 17" LCD Monitor
Computer speakers are buzzing
Common humming sounds from computer sound systems stem from the follwing:
1) Interferance with other electrical componants / devices
Solution: EMF / Radiostatic shielding may provide the solution
2) Defective componants
solution: try the hardware in another PC, if it still hums, your board / plug-in compants may be defective.
3) Jack(s) - Headphones / speakers have loose connection
Make sure everything is plugged in securely, and your jacks have not been damaged, also make sure you are plugged into the correct ports.
4) Microphone boost / auxiliary settings
check your sound settings, disable any ports you aren't using. Line-in, Aux, CD-rom, Digital Input.. if they aren't being used, they may be creating "whte" static in the lines. Muting them, or disableing them in the sound settings for your device may provide the solution..
5) It has been known to happen that certain CPU / Case / Power supply fans emmit a sonic frequency through the speakers due to EMF expulsions from the electro-magnetic motor. This is rare, but is possible, Disable the case fan to determin if it's the culprit, swap power supply, or CPU fan to determin if they are the issue.
WARNING: Never run your PC without the CPU fan in full operation, Never run the PC without your Power Supplies fan in full operation: This can lead to DAMAGE to your PC.
On a personal note: My card has several different ports, make sure you are plugged into the correct port, and muting the Aux cleared the humming in my computer's sound system.
Jan 13, 2009 | Philips MMS 321 Computer Speakers
NAD T770 (T2 Monitor button)
the best solution for this problem is to throw it away and never buy nad again. its junk.
Apr 21, 2008 | NAD T770 Receiver
225 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
