Question about Sunbeam SCA052MWC1 Air Conditioner
Air conditioner will not cool bedroom
Purchased a sunbeam air conditionr abd it does not blow cold air it also makes a cracking noise what can I do
  • 29 Answers
It sounds like the unit is failing to refrigerate, the cracking noise is most likely a compressor fault (trying to run) it may be stalled or have suffered a motor failure. The noise may also be an electrical short but unlikely as this would trip the safety trips in the house.
If you still have warranty i would return it or demand a HVAC engineer to inspect and repair faults.
all the best
Posted on Jul 05, 2010
We installed a 12,000 btu Frigidaire unit last night and it doesn't seem to blow 'cold' air. And it doesn't cool our tiny 12x12 bedroom...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 26, 2010 | Frigidaire FAC126P1 wall/window Air...
Air is not cold, and a wierd cracking noise
You are required to get the AC serviced which you can do it yourself except the checking of cooling gas. Unplug the power cord. Remove the AC from the frame. Take it near to a water point where it can be washed. Remove the front filter and clean it with a mild soap solution. Next take a water pipe and spray water jet in the air vents/fins. Let it dry. For cracking noise connect the power cord and run the AC locate the noise. If it is any loose part fix it or provide necessary packing to avoid vibration noise. When you are running the AC check if there is moisture condensation on the cooling pipes. If it is there then the gas is OK otherwise you have to top up the cooling gas. If the sound is coming from the compressor then you have to change the compressor. Re assemble if you are satisfied that the gas and compressor defects are not there.
Jun 28, 2010 | Heating & Cooling
My air conditioner is on but not blowing cold air and buzzes
The compressor is not starting. The buzzing noise you hear is the compressor trying to start and then the thermal overload trips. When it cools it will try to start again. Could be a bad capacitor or the compressor is bad. These two units need to be tested to see which one is bad. A capacitor is inexpensive. If it's the compressor it will be cheaper to buy a new AC.
Aug 21, 2009 | Heating & Cooling
Doesnt cool small bedroom with doors shut. I have
it should freeze that room with 9000btu do you hear the compressor turning on or is it blowing jus air? also helps if you switch the air intake to recirculate the room air rather than intaking the air from outside
Jul 30, 2009 | Maytag Portable Air Conditioner M6P09S2A
I have a sunbeam 12000 btu window unit air conditioner. I can't seem to change the fan speed when it is in cool mode. When I put it on fan only it blows extremely cold air and i can change the fan speed. ...
Sounds like the switch is wired wrong.
When you put the switch on fan only the compressor should not run at all, therefore their shouldn't be any cold air.
Check the switch to see if it's wired right.
Jul 29, 2009 | GE Profile ASM10AA Air Conditioner
Does not seem to cooling very well
clean both the evap coil and the condensor coil
Jul 13, 2009 | Amcor NanoMax A12000E Portable Air...
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
Air conditioner on 2002 Pontiac blowing hot air, although freon is not low...also makes a clicking noise.
Take it to a garage and have them evacuate the system and refill with refrigerant. you have air and non condensibles in the refrigerant system.
Jun 02, 2009 | 2002 Pontiac Sunfire
Blows warm air
you need to disassemble the rear fan shroud and clean the back of the condensor. If the compressor runs and the lines are cold, it is dirty. The rear condensor is the one discharging the hot air. Both sides must be clean and free of dirt/grime
May 06, 2009 | Sunbeam Heating & Cooling
Sunbeam SCA052MWC1 Air Conditioner Logo
183 people viewed this question
Top Sunbeam Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Are you a Sunbeam Heating and Cooling Expert? Answer questions, earn points and help others
