Question about Sanyo DP32648 32 in. LCD TV
The TV shows no indication of a working power supply. The LED on the front panel does not light. The fuse on the PS is good. It's conceivable that the PS is good and the mainboard is bad, Is there anything I can test for (e.g voltages at the PS) or look for (e.g. board mounted LED) to identify the problem board? Thank you, Bob bobf645@aol.com
  • 518 Answers
Have you got a good meter but watch the mains .it bites
Posted on Jul 05, 2010
Replaced power supply board but tv still wont turn on
Hi, You might also look at the capacitors on the main power board they are the first to go (Bad) Look for bulged caps and or leaking.
Replace them with same ratings. Good luck
Jan 30, 2016 | Sony KDL-70R550A 70" 3D LED TV 1920x1080,...
I blew a fuse and everything in my room, computer, playstation and the tv turned off. When i switch the fuse back on, the computer and playstation was working but the tv is not. Is there a chance that I...
Hi Jonathan,
Yes, if there's no LED light at the front panel of the TV, this is an indication that the power supply is not working (I'm assuming that you've already tried to plugged it in to other working outlet). First thing to check is the internal fuse of the TV. If you found it open, replaced it with same current(ampere) rating and try to power it on again. If the new fuse blow again this is an indication of more serious problem in the power supply. You may replaced it with a new board or seek for an assistance of a qualified TV technician to troubleshoot the board.
If you found the fuse intact, still the same problem(power supply board).
Please let me know if you need further assistance.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 20, 2011 | Televison & Video
No power and no glow to the screen. I'm assuming a power supply problem and I'm looking for a tear down of the unit. I also understand there are some fuses inside the case as well. Visual...
U have power to the tv is that correct?Yes?Power led light indication solid green,when tv is on but u have a blank screen no picture to the LCD screen panel at all?Yes?Than this problems it is not the tv power supply board problems.The tv Tuner signal board is it the cause and the problems.That the board where the incomming broadcasting signal cable plug into it.This board are 90%-95% are not repairable or troubleshoot able,because it almost all micro components parts and micro chips and most of them are surface mounted it on.This tv Tuner signal board can be only replaced with a new whole refurbish one only.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board for the replacement.
Aug 11, 2011 | Insignia NS-LCD47HD-09 47 in. LCD TV
My panasonic tc-p42c2 was working perfectly then it slowly died to now not even turning on any answers would help alot ?! please please
The tv now,it is take about 2 or 3 mins for the picture to show up or no power LED light indication to the tv at all or power LED light indication it is flashing now?This problems it is the tv power supply board problems.That the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
May 09, 2011 | Panasonic TCP42C2 42 in TV
TV will not turn on. Model SV370XVT 1 yr old Made sure was plugged into a working plug. Used both the remote and the power button on the TV to no avail.
U have a front screen panel LED light indication are flashing or totally dead,no LED light indication at all?Yes,than the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv power supply board for the replacement.
Dec 04, 2010 | Vizio L37 Television
Clicks and red light shows but dosn't have enough power to start up the TV. Is it the fuse?
No,it is not the fuse.The tv LED power light indication on the front of the LCD screen panel flashes?Yes.The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.If u have tools like a soldering iron,a desoldering pump or a roll of desoldering braids,a roll of solders.Know basic electronic and also can do basic soldering work?U can check the power supply board for those dying and to be dead parts call the capacitors.These capacitors parts alway bulges up on it tops or puffing up on it tops.By replacing these dying and to dead capacitors will be fix the power supply board than,no needed to buy the whole refurbish power supply board for the replacement.
Nov 12, 2010 | LG 42LG50 42 in. LCD HDTV
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
Sanyo DP5747 Plasma TV no power
Found 1 of the 2 ac supply ( 8amp) fuses blown on the main pwr. supply. Replaced fuse and good so far. Looked over the ps for damaged components, none found. Checked current with ampmeter with tv on, showing 3amps. Cheers
Jan 03, 2010 | Sanyo Televison & Video
Sanyo DP32648 32 in. LCD TV Logo
354 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
