What is the solution to get the 1000 using eight 8's
888+88+8+8+8
Posted on Jun 10, 2012
    Scholar:
  • 96 Answers
It will be:
8 X 8 + 8 + 8 + 8 + 8 + 8 + 8 + 8 + 8 X 8 - 8 - 8 -8 =1000
Hope this helps.
Posted on Jul 05, 2010
How many spark plug wires does a 2003 Dodge ram 1500 hemi have
Eight...
2003 Dodge RAM 1500 5.7 liter Hemi V-8 VIN "D"
Dont forgetted rate this answerr. Good luck.
Nov 02, 2010 | 2003 Dodge Ram Maxi
Hi i am gettin E061 0423 error on the canon clc1000, what is the problem, and how can i turn this copier on service mode. tanks a lot
try "*” (Additional Functions) button, then immediately pressing “2” and “8” together, followed by the “*” again. This is known affectionately as the “star-twenty-eight-star” among Canon service techs.
Apr 03, 2010 | Canon CLC 1000 Color Copier
Math
Do you mean 8:1000 as a ratio?
8:1000 can also be written as 8 / 1000
This can be reduced by dividing both sides by 8
8 / 8 = 1
1000 / 8 = 125
8:1000 = 1:125
Oct 15, 2009 | The Learning Company Achieve! Math &...
Unlock code for J700
0 8 0
its eight zeros 00000000
Jun 26, 2009 | Samsung J700 Cellular Phone
What are Rappel devices (descenders) and what kinds are there?
These devices are friction brakes which are designed for descending ropes. Many belay devices can be used as descenders, but there are descenders that are not practical for belaying, since it is too difficult to feed rope through them. Figure eight Sometimes just called "eight", this device is most commonly used as a descender, but may also be used as a belay device in the absence of more appropriate equipment. It is an aluminium (or occasionally steel) "8" shaped device, but comes in several varieties. Its main advantage is efficient heat dissipation. A square eight, used in rescue applications, is better for rappelling than the traditional 8. Because of the "ears" or "wings" on the rescue 8, there is less chance of forming a girth hitch whilst rappelling very quickly. A figure eight descender Figure eights allow fast but controlled descent on a rope. They are easy to set up and are effective in dissipating the heat caused by friction but have a tendency to put a twist in the rope. Holding the brake hand off to the side twists the rope, whereas holding the brake hand straight down, parallel to the body, allows a controlled descent without twisting the rope. Because of the many bends it puts into the rope, an 8 descender can wear a rope quicker than a tube style belay/rappel device. Many sport climbers also avoid them because of the extra bulk an 8 puts on the rack. However, many ice climbers prefer to use the 8, because it is much easier to thread with stiff or frozen rope. Rescue eight A rescue eight is a variation of a figure eight, with "ears" or "wings" which prevent the rope from "locking up" or creating a girth hitch, thus stranding the rappeller on the rope. Rescue eights are frequently made of steel, rather than aluminium. Rack This consists of a 'U' shaped frame, attached to the belayer's harness, into which snap multiple bars that pivot from the other side of the frame. The rope is woven through as many of the bars as are required to provide sufficient friction. This arrangement allows for variations in rope diameter and condition, as well as controlled rate of descent.
Dec 01, 2008 | Black Diamond Super 8 Belay Device
English
Let x = the investment return at 8%
Then x + 350 = the investment return at 9%
The investment at 8% + the investment at 9% = $2350 or x + x + 350 = 2350
Solving for x gives x=1000 Return at 8% was $1000 Return at 9% was %1350
Investment at 8% is formulated as follows. Y = (Initial investment) (.08) = $1000
.08Y = $1000 Y=$12,500 Using the same process for the 9% investment yields an initial investment of $15,000
Initial Investment at 8% = $12,500
Initial Investment at 9% = =$15,000
Hope this helps Good Luck Loringh
Sep 13, 2008 | Bagatrix Algebra Solved! 2005 (105101) for...
Help me pls...
use your calculator and perform the division...that would give you the answer in decimal form.
1. 0.90....
2. 0.56
3. 0.60
4.0.033 and so on...you can do it....
Jul 06, 2008 | Audio Players & Recorders
Tascam 2488 Portastudio
To record the eight inputs onto 8 separate tracks at once simply plug your mics or other audio sources into the mic inputs (only 4 can be powered, A-E) and then assign each input to a separate track by pressing the input button which corresponds to one input and then the select button for the desired target track at the same time. Do this for all eight inputs and their target tracks. Then arm all eight tracks to record by pressing the record buttons on each (the red lights will come on). Then when you press play and record in the transport section (or use punch operations) you will record all eight inputs to all eight tracks at the same time.
Good luck.
bd.
Jul 06, 2008 | Tascam 2488 Portastudio Multitrack...
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
