I am unable to locate any dishwasher with model Bendix 12.
The closest I can find is Bendix DH102. Please compare your unit with the user manual I have found and let me know if it is similar. The other one is CDW12 which appears to be much older. See manual.
Let me know if are in USA as I am assuming the Tricity Bendix dishwashers are only available in the continent.
1 Turn power off to refrigerator.
2 Open the fresh food sections door and remove all items on top shelf.
3 Adjust the fresh food control to its coldest position.
4 Remove the light shield by pulling down on the back corners of the cover
and then slide the cover forward.
5 Remove the edge sealing device, radiant shield supporting screws at the
back bottom center of the control housing mounting screw at back, bottom center
of the control housing. Slide the control housing to the right and lower the
housing.
6 Disconnect the temperature control housing from electric quick disconnect.
7 Remove the temperature control housing from the refrigerator and then
place on a
flat work surface.
8 Remove the auto damper control rod retainer, control rod and the slide
control
gear from the auto damper control.
9 Now turn the control housing over.
10 Remove the two auto damper mounting screws, then remove the auto damper
from the control housing.
11 Mark the auto damper rod about 1/4 in. from and away from the housing.
12 Uncoil the auto damper capillary tube at about 4 in.'s
13 Submerge into a glass of ice (not water). then watch for door to move to
the closed
position.
14 Remove from ice and warm capillary tube with your hand. Then watch door
for an opposite reaction.
15 If no movement is detected, replace the control. 61005971
Damper Control Assembly
The above is only a demostration of how to test a refrigerator with an auto that uses a capillary tube to open and close the damper. Your refrigerator will need to be identified by the correct model number to let you know what type of auto damper your model has, Post your model number and I will tell you what you will need to test yours, Thanks Sea Breeze
