Question about LG Dishwashers
My LG LD 2130WH dishwasher is showing an error of 1E -- the mains water is ok -
MNTECH
  • 1543 Answers
SOURCE: 1E error LD-14aw2
I do not have specific info on your model, as I believe it is one not intended for USA distribution (where I am at) but, you might want to check the following, which applied to some LG dishwashers produced between Jan or 2005 and Feb. or 2007.
The black mastic sound insulation material inside the dishwasher door can soften from the heat inside the dishwasher, allowing the wires inside the door to become embedded in it. If this has happened, the insulation on the wires can soften and begin to dissolve, resulting in shorted or broken wires. This may cause various error codes which may send you on a wild goose chase.
Take the screws out of the door and inspect the black insulation and the wires. If any wires are embedded in the black mastic, you may cut them and bypass them with a new section of wire, then make sure to add an insulating material to separate the wires from contacting the black mastic. In severe cases, the inner door panel must be replaced (they no longer use that type of mastic) and the wiring harness for the dishwasher would also be replaced. (a set of all the wires and plugs).
Posted on Aug 25, 2009
SOURCE: I have the same problem !!!
I have the same thing happening to my dishwasher what do I do
Posted on Oct 19, 2009
chargerhp
  • 814 Answers
SOURCE: LG Dishwasher LD-2050WH with HE error code
LG Told me the water coming in was to hot and to disconnect power for a few seconds and reset water heater to around 120 deg
Posted on Jan 31, 2010
  • 3 Answers
SOURCE: LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
Posted on Nov 07, 2010
  • 3247 Answers
SOURCE: I have an LG Dishwasher, LD-2120 WH. When I switch
The error 1E usually means some problem with the inlet water system. Could as simple as the inlet hose filter is clogged, water pressure is low, inlet solenoid is faulty or worse the sensor detecting level of water in dishwasher is faulty and is telling the dishwasher that it is not filling up.
Do you have any water at the base when the fault comes on?
Posted on Dec 13, 2010
LD-2040WH
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Aug 27, 2014 | LG Dishwashers
Model LD 12AW2 not drawing water displaying 1E error
Hi afarugia,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 10, 2011 | LG Dishwashers
I have an error code of 1E on my LG dishwasher what does this mean and how do I fix it?
1E error is Not reached to the normal water level in spite of 10 min. water supply
POSSIBLE CAUSE REMEDY FOR ERROR OCCURRENCE The Water Supply Tap is closed. The Water Supply is shut off. The Inlet Hose is kinked. The Water Pressure is very low. (below 10 psi) Inlet Valve is OK? The filter of Inlet Valve is clogged by impure water. The Hall sensor is OK? The Impeller of Air Guide is bound.
Remedy Take action on Water Supply device. Measure the electric resistance of Inlet Valve. (950-1300 ) Clean the filter of Inlet Valve. Check the frequency of Inlet Water by the Test Mode. Replace the Air Braker.
Sep 26, 2009 | LG Dishwashers
Keeps alarmimg 1E on my Lg Dishwasher
Inlet water error 1E
Sep 24, 2009 | LG Dishwashers
1E error LD-14aw2
Aug 25, 2009 | LG 24 in. LD-12BW5 Free-standing...
Aug 18, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher not working showing 1F in timer display
I am not aware of an LG code 1F. But there is an error code "1E"
After you double check that the water valve is open that feeds the dishwasher, focus on the inlet valve (solenoid)
As you remove the inlet valve, if you see the screen is filled with gunk, clean it and retest.
Good Luck!
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwashers Logo
130 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
