Question about Hotpoint Ultima WF860 Front Load Washer
Washing machine motor not turning
Hotpoint ultima washing machine. pressure switch ok but drum not spinning
    Genius:
  • 1,416 Answers
what this indicate is that there have been a power disconnection from power supply on the jet string connected to the drum (drum controller)
what you will have to do to solve this problem is to unscrew the the washer then trace the wire down to the jet it is round in shape at the back of the washer
please rate this
thank you
Posted on Jul 05, 2010
Hotpoint ultima washing machine wma74 drum not turning
If the machine wasn't excessively noisy before and when you select spin only you can't hear the motor running its likely to be the carbon brushes in the motor worn down till they no longer contact stick a new set in if the carbon length sticking out the brass holder is less than around half an inch long
Dec 08, 2013 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WT721 F 08 fault code
Try the brushes first. I'm guessing the carbon deposits on the floor are from the brushes.
Nov 16, 2013 | Washing Machines
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima F-05 errorr appears on machine
Error F05 indicates pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima wont spin, its as thought something is preventing it for spinning. When its switched to spin cycle it turns a little to the left, then a little to the right, but cant seem to go any...
Things that couse this are, worn motor brushes, unplug remove the top, the motor should be at the top, if so remove the wire attached to the spade of the grey cartridge then unclip using a very thin screwdriver pushed down the back of the cartridge, and slide out if there is only a small peice of brush showing they must be changed, if ok spin the drum by hand if it moves freely the the drum is ok, the last thing to check is if it moves through the wash, but its just the spin that it wont move, there is a blockage, and the preassure vessel wont allow it to spin.
Jul 10, 2009 | Hotpoint Ultima WD72 Front Load...
Drum wont move
Check the motor and the belt on the back of the unit behind the rear plate. Make sure that the belt is attached and the motor is spinning. If this helped please rate. Thank you
Feb 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing machine won't spin
Do you hear the motor spinning loud whirring noise,when drum is not,if so drum belt has come off or snapped,if no noise possible brushes on motor need replacing
Jan 18, 2009 | Hotpoint Ultima WD72 Front Load...
How do I replace the belt that makes the drum spin on a Hotpoint Ultima WF860 ?
The belt goes around the drum and onto the motor pulley. No need to loosen anything. Put tension on the belt and fit it onto the motor pulley by gently turning the motor and pushing the belt onto the pulley at the same time.
Oct 28, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
188 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
