My tv doesn't turn on any more and the red led doesn't light up
  • 518 Answers
Check fuse in plug. normally the problem
Posted on Jul 05, 2010
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
2001 Sony KP 61V90 61 inch rear projection TV has steady red power/standby light and thus is getting power, but doesn't fully turn on. I've read that this may be a fuse. Suggestions on repair?
Hello. I can help, but please could you tell me how many times the front LED blink?. After connecting and press power, see how many times the LED blink. are you sure the TV model is same as that spelling on your question?. send me your answer and will answer soon. thanks
Aug 14, 2011 | Televison & Video
I have a jumbo remote, lost my manual. I would like to program it to operate a sanyo tv. I need instructions please.
First, make sure the device you want to connect with your remote is turned on, whether that's the television, DVD player, VCR player, etc. Now aim the Innovage remote at the device. Press the button on the remote control that corresponds to the device (TV, DVD, etc.). Now, press and hold the SET button on the remote control until the LED light on the remote control holds a steady red.
Enter the 4-digit code for your device by pressing the number keys on the remote control (see list below). When you press the fourth digit, the LED light should turn off. This means the remote and the device are "speaking" to each other. Press the OK button to store the code.
If the LED light blinks three times and then remains a solid red, the Innovage remote doesn't recognize the code for your device. Verify the correct code, then go through the programming steps again.
Test the function by using your remote to cycle through all programmed devices (TV, VCR, etc.).
If your device code isn't listed, try the Code Search function:
Turn on the device you wish to match with your remote. Aim the remote at the device and press and hold the Code Search button in the upper left of your remote for at least 3 seconds until the LED light on the remote turns a solid red. Press the button on the remote for the item you want to program (TV, DVD, etc.). The LED light should blink once and then remain a solid red.
Press the On/Off button slowly until the device you want to program turns off. The LED light will blink once each time you depress the On/Off button. When the device you want to program turns off, press the ENTER button. The LED button will turn off and the code for that device will be stored in your remote.
The codes to various devices are listed at:
www.remotecentral.com
Please note that there are often several codes for one particular device. It may take several programming attempts until you find the code that works with your device.
May 20, 2011 | Innovage Jumbo Remote Control
I need the codes for the jumbo innovage control for an advent tv.
I don't see Advent TV codes in the Innovage Jumbo Remote manual.
Here are the Code Search instructions:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. the LED light will turn off.
Oct 11, 2009 | Innovage Jumbo Remote Control
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
I have a Jumbo universal remote by Innovage and I need the programing codes for the tv. Do you have them???
To program your remote by entering a code from a manufacturer's list, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Aug 21, 2009 | Innovage Jumbo Remote Control
Televison & Video Logo
Top Televison & Video Experts
