Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I do not know the original code for my garage door but i need to set my own code
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Jul 06, 2010
Do not have original remotes for opener. These original remotes hold the DIP code to program my new universal remote?
You won;t need the original openers for the newer garage door openers. There is a button on the back of the opener that you have to push to get the universal remote to sync with the garage door opener. The instructions that come with the universal remote are pretty good in explaining the setup.
Feb 02, 2013 | Cars & Trucks
On my 976lm keyless entry, it says to enter the code before doing a temporary code, How does that work when you don't know the original code to begin with?
Just do this.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Feb 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
We have an old sears garage door opener with one remote. it's model 139536006. There is no "Learning Button" on the motor, only a series of 9 code or dip switches that have to be set in one of...
You don't need the original switch positions. Make sure the row of switches in the motor unit are set exactly the way the remote is. The switches are normally marked + 0 -. Move all of them to the plus sign and try.
Jan 12, 2011 | Sears Craftsman LiftMaster Chamberlain...
Do you know how to get the adjustment controls back to the original factory settings?
The controls on every opener are adjusted to the condition of the door it is opening. The force adjustments should be set at minimum and then adjusted so that the door operates consistently. Do not set them too high as it affects the safety of the system.
Oct 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
I cant find instructions for setting the keypad to work with the garage door opener . I have a garage door opener from sears that is 18 yearsa old. someone stole my car remote and i had to reset the remote...
If your keypad is wireless, locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk to your keypad and key in any 4 digit code you like.
Aug 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to set acsctg type 2
There is a button on the motor head you can press. Press it then press the button on the remote 3 times and try it. If not try it again. Genies are bad for not coding in the first time. Make sure there are new batteries in it. Thanks BB
Jul 19, 2010 | Genie Company IntelliCode GICT390-1BL...
Our craftsman garage door opener's wireless keypad is broken
It sounds like the default no code is still there.
Reset the unitat the opener itself and reload your code from the remote.
Sep 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door Opener Can't Use Multiple Remotes!
THE UNIT CAN WORK WITH EITHER ROLLING CODE OR NON ROLLING CODE, NOT BOTH.
I WOULD GUESS THE CLICKER IS NOT ROLLING CODE.
I HAVE NEVER HAD GOOD LUCK WITH THE CLICKER REMOTES - GO AND GET ANOTHER REAL REMOTE - THE SAME SERIES AS THE ORIGIONAL.
GET A REFUND ON THE CLICKER - OR HAVE IT BRONZED FOR THE MANTEL.
HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Reset garage door code
Hi, The opener, remotes and keypads have a set of dip switches that you can use to change the code. You will find the switches when you open the remotes and keypad and are in the back cover ( depending on the model) of the opener itself. Make sure that the codes of all the switches are set exactly the same. If you need additional help let me know! Good Luck.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman (older model)
Do you have the option to change the electronic codes on your garage door opener system? My father-in-law had the same problem a number of years ago. He had not reset the code (equivalent to the combination on a lock) from the equivalent of 0-0-0 (which his unit shipped with). Turned out that a neighbor (or neighbour - in Canada) had the same /similar unit and when the neighbor opened 'his' door, my father-in-law's door would also open. You don't have to see the person drive by - it can be the neighbors behind you as well. You may find a solution by determining if you can change the original electronic code to a different one of your own choosing.
Hope this helps.
Dec 17, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
