Aircon is not cold heater is not hot
The aircon is cool but not cold likewise the heater is warm but not hot
  • 518 Answers
The air con unit need recharging
Posted on Jul 05, 2010
Hi I recently bought a new condenser and it was fitted and the aircon gas refilled, it works well when I set it to cold but doesn't warm up at all, even if I drove for a long distance.
air conditioners only cool , not warm up
that is the job of the heater
If you have a climate control in the system , check for a faulty control module
Apr 07, 2018 | Cars & Trucks
What is the temperture range hot/cold
This machine is energy compliant to an extreme. The installation says to have the water heater set to 120 and when you put the machine on HOT it will be cooler than that because it mixes the hot with some cold. WARM is a little more cold and COOL is mostly cold and some warm, COLD is just plain cold.
Sep 02, 2015 | Estate ETW4400TQ Top Load Washer / Dryer
My 2000 jimmy has heat problems. the heat goes from cold to hot to warm to cold etc. what could the problem be?
If the temp gauge is now more stable, the problem is in your heater system, not the engine cooling system.
Sep 12, 2014 | 2000 GMC Jimmy
Changing a honeywell T6060 room thermostat to a T6360B. The current wires are wired as 1 Red 2 has 2 Black and Live has another Red. Which of these wires should be connected where on the T6360B?
Can someone please tell me what a honeywall t6060 for and how to use it cause if it's for the aircon so its warm as well as cool then I'll like to knw as it dosentvwork past 15 and cuts out otherwise it's just cold and hot able thanks
Nov 21, 2011 | Honeywell Programmable Thermostat Heater
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
E180auto passengerside aircon always blowing cold 1992 model
Sounds like the vent control motor is bad. It controls how much hot water flows through the heater core. OR the heater core for that side is clogged
Feb 03, 2010 | 1991 Mercedes-Benz E-Class
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
Heater not working
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
I have a Ford BA Falcon but the heater does not work can you help
You'll most likely find your Air mix shaft has snapped - very common in the BA's and Territorys. Part only costs roughly $40, however the whole dash needs to come out so you can insert the new shaft. Less commonly it could be the HIM box
Aug 03, 2008 | Heating & Cooling
Heating & Cooling Logo
74 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
