Question about Toro Garden
Drive belt adjustment
We have a 16-38 HXL Toro Wheel Horse Lawn Tractor with new drive belt installed, 1/2 X 87, that goes in and out of moving forward at any speed. Backing up is fine - speed-wise - but going forward goes from snails pace to normal. Have I got the wrong size belt, or is there another problem? And how do I make drive belt adjustments? Thanks, RP
gisvc
  • 40 Answers
SOURCE: drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Posted on Mar 29, 2009
  • 85 Answers
SOURCE: 15 38 hxl moves slowly, trans won't pull on incline
If the transmission whines, the brake may be sticking. you may have to relocate the brake return spring, to the rear of the flange that the spring is currently attached to
Posted on Aug 16, 2009
  • 257 Answers
SOURCE: I own a toro lx 425 lawn tractor, now it wont go
you can check the idle pully to see if it is working,, spring could be stretched,,or you could need new belt, hope this help
Posted on Aug 30, 2009
suzukiracing
  • 200 Answers
SOURCE: toro lawn tractor 16-44 hxl
The spindles on the deck may need replacing.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Posted on Jul 20, 2010
  • 264 Answers
SOURCE: WHAT CONFIGURATION DOES BELT GO
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Posted on Jan 15, 2011
I need a deck lever assembly schrmatic for a toro wheel horse 14-38 hxl
Request the assembly diagram (not a schematic) directly from Toro.
Jun 09, 2017 | Toro Garden
What is wheel drive belt size for toro lx 426 lawn tractor
Motion drive consists of two belts,
Engine to variable speed pulley 5/8 x 90-1/2
Variable speed to transmission 5/8 x 42
May 30, 2015 | Toro Garden
I have a Toro 14-38 HXL 71193 I need the part number for the Drive belt
The belt you are looking for should be number 18 on the diagram if you follow this link.
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
and the part number shows to be a 88-6280
Hope this helps
Aug 24, 2014 | Toro Garden
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
Not getting any power from battery. won,t start and no lights on toro wheel horse 14-38 hxl. whats wrong with it?
Clean off all electrical battery cables free from corrosion and they maybe loose from vibration
Jul 03, 2011 | Toro Garden
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Jul 18, 2010 | Toro Garden
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
NEW WHEELS AND BRAKE ADJUSTMENT MOWER WILL NOT MOVE IN ANY GEAR
Is it a hydrostatic drive and did you pull the pin that is located by the hitch. The pin should be pushed in in order to engage hydrostatic drive.
Apr 13, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
420 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
