Question about Saws
Master craft reciprocating saw blade clamp replacement older model # 54-8148-4 part # 3101039 discontinued model can I get used parts Milwalkie tools dosen't quit fit
4 Suggested Answers
tomgswan
  • 30 Answers
SOURCE: We have a ryobi rj150v model reciprocating saw
There are 2 types of clamps that hold the blade in that type of saw.
Since this is an older one it most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Posted on Jul 01, 2011
joboo1
  • 257 Answers
SOURCE: I need instructions on removing the front housing
Hi again Guy, It is easy to overlook the obvious, I do it a lot. There are two allen screws in the rubber boot at the front bottom that need to be removed to release the foot (or shoe), which should slide out the end. Then the whole boot ( forward hand grip) pulls off the end exposing the assembly you need to replace. Good Luck to you, this should Fixya!
Posted on Mar 23, 2009
  • 864 Answers
SOURCE: need replacement seal gasket for sears reciprocating saw 172.2677
Check for Sears parts online or see if Black & Decker has a similar part.
Posted on May 20, 2009
How do I replace the tool-less blade clamp in a craftsman 8 amp reciprocating saw
Craftsman Reciprocating Saw replace the tool-less blade clamp
Jun 10, 2015 | Craftsman Saws
Blade clamp
i purchased a clarke reciprocating saw, and the first time i tightened the blade it broke, where can i get the parts to fix it
Mar 09, 2014 | Clarke Power Products Electronic...
Where can I purchase a clamping plate for my Bosch 1632VS reciprocating saw
This part has been discontinued by Bosch and several aftermarket parts dealers I use no longer have any. There is currently one listed on eBay for $7.96. Just search on "BOSCH 3600690504" and it'll come up.
Feb 07, 2013 | Bosch 3600690504 Clamping Plate
Blade too thick got stuck
lock the blade in a vise or grip it tightly and with the clamp open TAP on the shoe to pull the saw away from the blade. Use gloves and unplug the tool before attempting.
Jan 05, 2012 | Makita JR3030T Variable Speed...
We have a ryobi rj150v model reciprocating saw (older model) which needs the blade replaced. It had a broken part, which I ordered several years ago. My husband's FINALLY going to replace the blade,...
Jun 30, 2011 | Ryobi Saws
I need directions on how to change the baldes on a reciprocating saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
Cannot put blade into 310 reciprocating saw the instructions in the manual do not make it clear
Point tool away from body.
2. Rotate blade clamp collar (the knurled diamond pattern knob just at the back of where the blade goes) to release position.
3. Insert blade shank from the front.
4. Rotate blade clamp collar to lock blade into position.
May 25, 2011 | Dewalt DW310K Heavy Duty Reciprocating Saw...
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Saws Logo
768 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
