Virtual surround sound --only one earpiece works--this is my second pair-first pair stopped working also but was replaced within 30 days buy retailer
  • 1,512 Answers
Hi bleewilke
I am afraid that you may need to do the same again. If they are getting broken at the plug end, you may be able to replace the plug, but modern cables need to be clamped in a moulded plug to retain any strength, a repair like this will probably fail also. Replacement is generally the best option. are they still under warranty
regards
Graeme
Posted on Apr 18, 2008
Can't hear through the ear piece. must use speakerphone
Typically when the earpiece (or speaker for that matter) is not working, that indicates that the component is faulty. In order to correct the issue, a replacement part must be installed.
Due to the popularity of the Razr V3 series, replacement pats are not difficult to find. Also, due to it's age, these parts aren't expensive to replace either.
Online retailers, such as eBay typically provide the easiest access to such parts, in this case, the earpiece should cost only about $4-8 with S/H included. The downside being that the Razr would need to be opened in order to replace the earpiece and depending on the level of experience of the end-user, it could be rather difficult to get to some of the Razr's interior components without damaging others.
There are online retailers that provide this type of service and it will usually cost anywhere from $35-85 for a flat fee repair, but that may not be cost effective given the age of the Razr.
Another alternative is to purchase a relatively inexpensive headset and pair it with your Razr. It will provide both the incoming/outgoing sound and can be purchased for between $6-30. Note that there are two types of headsets: wired and bluetooth, with the bluetooth sets at the upper end of the price scale and the wired set at the lower end.
Lastly, if the Razr is still under warranty or you have insurance coverage through your provider, this type of failure is covered under the terms & conditions and could be replaced with a new phone for little to no out of pocket expense for the end-user.
Aug 11, 2010 | Motorola Mobility RAZR V3
The right earpiece doesnt work
Sooo... how many times will it take for you to switch to another kind or earpiece? Sorry...Door waas wide open for that one.
Dec 28, 2009 | Skull Candy Smokin' Buds Headphones
No outgoing calls can be made, says "Call Failed"
There is a possibility that the phone is still recognizing the Bluetooth earpiece and it's interfering with the phone's operation.
Once you pair up two Bluetooth devices, they would remain paired up regardless if the devices are turned ON or OFF. You need to enable the Bluetooth of your BlackBerry and find the way on how to unpair the earpiece.
Once it's unpaired, remove the battery from the phone while the phone is turned ON. Leave it for 5 minutes and then put the battery back and turn the phone back on.
If the problem still occurs, then you might want to contact BlackBerry to check some other settings.
Have a great day!
Sep 26, 2009 | AT&T Blackberry Curve 8300 Smartphone
Bluetooth connects to LG Vu phone but does not work
I would suggest taking the battery out when the phone is powered on. Replace the battery and try to re-pair the set.
If that doesn't work, then its likely the bluetooth module in your phone is broken. You can validate this by pairing the bluetooth with another handset.
Jun 30, 2009 | LG Shine CU720 Cellular Phone
Download virtual surround sound drivers
i have the acer 6920g notebook and had windows 7 installed and cant get my virtual surround sound working can you give me any clues. thanks
May 04, 2009 | Acer Aspire 6920 Notebook PC
Screen says ''unusable signal''
Okay,if you purchase this TV brand new at a Best Buy or Circuit City within 30 days,i don't see you will have another problem to have them replace it for you?If you have purchase it brand new with other retailers,you need to read their warranty status.If they do not specify within 30 days or one year warranty by THEIR company with a replacement guaranteed,you will have a hard time to get a new tv from this retailer.
If you bought online,sorry man:(
solutiodoct
Nov 11, 2008 | Televison & Video
Ear piece does not work. Station top light does not come on
The 500A base station is definitely compatible with the 510 earpiece. If the earpiece is turned off or unpaired the base station's red power light will be flashing. If the earpiece is already off, try turning it on by holding down the little black button on top. The base station will automatically try to find the earpiece and the blue light on top of the base will come on. If the earpiece is already on (slow flashing blue light on the mic boom) turn it off and back on again and wait for the base to find it.
Nov 10, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Earpiece stopped working
That is at your local dealer... LG will give you 1year warranty.. Anyways it seems to be a problem with the earphones.. Did you try a different set of earphones?
Mar 18, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Motorola H350 - Incoming calls
there is nothing you can do about the delay as it's the time it takes for the bluetooth to send the signal to your earpiece to tell it the call is answered, the only way to stop any delay is to set your phone to auto answer in the bluetooth headphone settings or in the call settings.
Aug 07, 2007 | Motorola Mobility H350 Wireless Headset
56 people viewed this question
 Grubhead
Grubhead
