Question about Mitsubishi MSY-A15NA Split System Air Conditioner
Mr Slim is dripping condensation into the room. I use this to heat and cool a 500 sq ft finished space over garage. I have been looking for troubleshooting guides but no luck. It is cooling the space, so condenser appears to be functioning. Filter and unit is clean. Any idea on what's going on? Unit is about 18 months old and has worked flawlessly since the start. Any help would be appreciated.
  • 29 Answers
Firstly i would try and establish if the unit is on a gravity drain or a pumped drain.
1. If the drain is gravity it means the condensate water will flow with gravity normally straight through the wall, so check for blockages outside and inside, the unit may look clean but if it hasn't been serviced there may be a build up of dirt in the drain.
So try and locate the outlet of the drain outside (normally by the refrigeration pipework to condenser) and attach a wet hoover to it and make a good seal, this will **** any water/dirt out of the drain line.
2.If its on a pump, a small water pump which collects the condensate in a sump and then pumps it away when a float is activated. (Normally fitted if a gravity drain option is unavailable).
You can check to see if the sump is full and overflowing which is an indication the pump/float has failed and will req replacing by an A/C company. Or the PVC drain line is blocked with dirt.
The pump is either located behind the unit in the casing, or in the white trunk containing the refrigeration pipework
All the best
Posted on Jul 05, 2010
Preset heat stuck at 63. I want to lower the temperature for a vacation
[PDF]PAR-30MAA - Mitsubishi Electric Australia
https://www.mitsubishielectric.com.au/.../IB_PAR-30...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote Controller ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F). Auto. 19 ~ 28 ?C (67 ~ 83 ?F). Fan/Ventilation. Not settable. 13 ...
[PDF]PAR-31MAA - Mitsubishi Electric Australia
www.mitsubishielectric.com.au/.../par-31maa_ib_en.p...
Mitsubishi Electricand Mitsubishi Mr. Slim Air Conditioners. MA Remote ..... Heat. 17 ~ 28 ?C (63 ~ 83 ?F) .... Preset cooling temperature is higher than preset heating temperature.
My air recycle button just blinks. Also when i turn on the - Fixya
www.fixya.com/support/t26081705-air_recycle_button_just_blinks_also
6 hours ago - Not sure the heat pump is producing enough heat. Nov 04 ... Preset heat stuck at 63. ... Feb 05, 2016 ' Mitsubishi Electric Mr Slim E12C26426.
[PDF]MA Remote Controller Mitsubishi Electric PAR-21MAA ...
planetaklimata.com.ua/.../Mitsubishi_Electric/Mitsubishi_Electric_PAR-2...
Easy Maintenance Function (Only for Mr. SLIM PUHZ series) . .... 4.4.3 Automatic Cooling/Heating Display Setting . ... Monitoring the Operation Data by the remote Controller (for Mr. SLIM) .......... ..............48 . How to .... 63. 4.2 How to set rotation function(back-up function, 2nd stage cut-in function) . ... Preset temperature (. °C. ).
Feb 05, 2016 | Mitsubishi Electric Mr Slim E12C26426...
Mr. Slim aint cool!
Unit short of refrigerant or outside condenser very dirty. Clean outside thoroughly and make sure there is plenty of warmth coming from it when working.
Jul 07, 2012 | Mitsubishi MSZ-D30NA Mr. Slim Wall Heat...
Operating indicator light is flashing on Mr.Slim A/C
I had the same problem and I found it was that another unit had the heat running while I was trying to run AC on another (they're both attached to the same condenser) so it could only run heat or AC not both. Turn off the heat!
Mar 25, 2012 | Mitsubishi Mr. Slim MXZ30TN Air...
Hi - I have a MR SLIM MSZ A09NA HEAT PUMP. It is dripping inside the room. It was installed in 2008. Is seams to be loose on the wall. Is it supposed to be level? tipped to the right ?
An air conditioner should be installed so it's level. These appliances are designed so that condensate collects below the fan and runs into the slinger ring, which is made of sheetmetal and is part of the fan assembly. The bottom of the ring acts like a gutter to collect condensate. The fan then picks the water out of the ring and slings it against the condenser coils.
Recycling the condensate in this manner increases the coils' cooling capacity. Check the air conditioner for level -- front to back and side to side -- when you install the unit.
If it is tipped a little to the Front then you will Get water inside room.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have 2 of the MSZ-A09NA Mr. Slim model in my 400 sq. ft. cottage. In the summer time my cottage is always damp feeling and the ducts drip condensation. How do I prevent this dripping?
It sounds like you have too much air conditioner vs. conditioned space. This would cause dripping and short run times. Air conditioners are designed not only to cool the house but to pull the moisture out, if it is too big and cools the area too fast the outside of the ducts will begin to collect condensation like the outside of a cold glass of water.
May 04, 2011 | Mitsubishi MS09TW Air Conditioner
Does this unit have capity for an 1000 sq ft room? what is this unit?
input is 30,000 Btu's. Output is probably 20% less. You should expect 15 Btu's per square foot. I would say you are fine, but not knowing where on planet earth you are so anyone would be guessing.
Dec 11, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim unit "spits" water/dust mixture
some of those units are equipped with a condensat pump you could have a loose connection or a small crack in the line
Jul 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Slim air unit is blowing out dirt into my room.
Simple matter of cleaning the unit. You have to clean the filters, the coil and around the louver.
Jun 06, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubish mr Slim air contioner heat & cooling control panel
HOW TO WORK THE HEATING AND COOLING CONTROL PANEL
- PRESS THE SWITCH ONCE IT OPERATES "COOL"
- PRESS THE SWITCH AGAIN IT OPERATES "HEAT"
- PRESS THE SWITCH ONCE AGAIN IT STOPS.
Mar 05, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi MSY-A15NA Split System Air Conditioner Logo
840 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
