Question about Karcher K 3.98 M Electric Pressure Washer
Water leakage trickling underneath
Water leakage
  • 518 Answers
Has to be a seal which needs replacing
Posted on Jul 05, 2010
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Rf266. Water collects under the bottom drawer of the refrigerator and results in leakage underneath onto the floor
Can you click HERE and read and or watch the video's so you can get an idea of what needs to be done behind the rear panel of the freezer to unblock the condensate drain Leaking Refrigerators.
Thanks, John Tripp Appliance 911
What is the model number?
May 01, 2014 | Refrigerators
Water leaking under the machine
Take a look at the little spout area that pours into the water tray. It can get clogged with coffee grounds. This was our solution with one machine. But with another, the water was actually leaking out the back and was the result of a dying boiler assembly.
Dec 12, 2012 | Saeco Vienna Plus Espresso Machine
Water leakage. cleaned back area so fan free of dust and water in pan is evaporating, any other ideas where leakage could be coming from
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 24, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Radiator replaced july 2009, upper/ lower hoses no leakage
When the water pump goes bad it has a valve that sprays coolent out of the bottom water pump so it may need replaced.
Jun 30, 2010 | 1985 Oldsmobile 98
Kenmore HD Series 80 - hot water trickles in.
Pull the two screws at the bottom corners of the control panel. Pivot the panel up. Lever the two metal keepers underneath forward and up to remove them. Tilt the housing forward and pull it toward you to remove it. Make sure you unhook the lid switch wiring plug before you remove the housing.
Water inlet valve should all be one piece for hot and cold.
Nov 15, 2009 | Kenmore 26882 Top Load Washer
Everytime I add coolant or water it instantly leaks bach out under the SUV. It trickles down the oil pan to the ground. Is this leaking from the water pump?
betya booties is is the water pump.try adding water while engine is running ,if the rate of leakage seems less ,it is definately the water pump. iwould take it to a radiator repair shop andthey will check for sure i doubt they will charge you as it only takes aminute , good luck.
Aug 01, 2009 | 2006 Kia Sorento
Leakage of water from underneath when filling machine up
it's prabably your pump it has two metal strips that snap on from the motor to the pump un-snap them and undo your hoses and get yourself a new pump
Apr 03, 2009 | Washing Machines
Gld5860l00ss QuietPower2 water leak
did you fix it yet ? check water line fittings underneath if you can pull a bit out washer to watch underneath when running to see where and when in cycle it leaks don't touch any electrical connections safety first LOL. disconnect power wipe dry and then ren it through a quick wash or other cycle and see.
Jul 10, 2008 | GE 24 in. GLD5860LSS Stainless Still...
Karcher K 3.98 M Electric Pressure Washer Logo
149 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
