Question about Canon CLC 5000 Copier
Runshort of clc 5000 consumbles like drum,blade,greed, toner can you help procuring ?
  • 1,219 Answers
try to locate Katun dealer, its not genuine parts, but they arent bad. www.katun.com.
Hope that helped
Posted on Jul 05, 2010
Where is location of cleaning blade drum minolta 4000 copier
Remove the drum unit/cartridge once done remove the (BE CARE REMOVE DRUM BY PUSHING UNDERNEATH FROM THE END NO FIIGERS MUST TOUCH THE DRUM BE CAREFUL NO NICKING IT EITHER) drum you will see the cleaning blade on your left of just where the drum came out if it is yellow looking replace it. When you replace it make sure you prime it with some toner out of the toner bottle. use a brush on the inside of the blade entire length also prime drum area entire length that is going to make contact with blade intialiy then once the drum is in turn the drum backs wards just a little (This will prevent the blade form FLIPPING! not good then turn the drum toward the right until it comes full circle and all the toner is removed from the entire drum
Jan 29, 2014 | Minolta EP4000/5000 CS/PRO Copier
Irc3580i
A E000013-00 code is not a very good error code to have..... It has to do with the waste toner feed screw is "Backed up with toner" > most of the time you have to take the drum unit out & remove the drum & cleaning blade & chip out the toner in the tray under the drum blade. The other part of the problem is that the waste toner bottle is full and the feed tube in the back of the copier is packed up with toner and needs to be cleaned out. Also, there is a gear that may have cracked that drives the feed screw. This not a easy fix...
Good Luck
Sep 12, 2012 | Canon imageRUNNER 5000 Copier
I have a CLC 5100 printer. I just replaced the starter/developer for all four colors. I have pink streaks on the top of every page. Whats wrong?
While replacing starter kits, it is always necessary to replace also the drum and blade for each of the four cartridges that is cyan, magenta, yellow and black. Check the cyan cartridge and make sure the developer on the magnetic roller is well spread and even then check the drum and blade and make sure no line is visible otherwise replace the drum and blade. Good luck.
Jan 28, 2011 | Canon CLC 5100 Copier
There is a dark vertical line of toner on prints
Common problem. Most likely caused by a bad drum cleaning blade. This is especially true if you run say 10 copies and the last copy out of the machine is worse than the first copy out. Drum cleaning blades are cheap at less than $30.00.
Good Luck and Thank You using Fixya.
Sep 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
Error message "wire cleaner needs to be changed" what is that?now prints all black.
If prints all black,yuor problem in the optic section.Please check the exposure lamp,termofuse.If your problem to be charge or transfer/separator corona wire the copy is blank.If posible OPC drum cleaning blade damage or used toner rotative mehanism blocated.
Aug 01, 2009 | Canon CLC-700 Copier
Canon ir5000
assuming it is a black patch of toner, the drum blade needs changing or the waste toner mechanism needs to be looked at
Aug 27, 2008 | Canon imageRUNNER 5000 Copier
CLC 1120 code e071, sub code 001
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors ther may be toner or paper dust.
May 20, 2008 | Canon CLC 1120 Color Copier
Victor enriquez
there maybe a piece of paper or some dust in one of the transfer drum drawer connectors, also in the transfer drum home position sensors there may be toner or paper dust
May 15, 2008 | Canon CLC 1120 Color Copier
old marine
old marine
