Question about Dishwashers
Who does repairs of Tecnik dishwashers in Nottingham NG12 2NF. We have a broken pump. Thank you
  • auer34 Jul 06, 2010
    I did not receive any meaningful help at all until now - the list of companies sent is totally unspecific and does not have anything to do with my specific question: who does a dishwasher repair of a Tecnik dishwasher in Nottingham.
    The list I got so far equals the one which I can open on the internet at a mouseclick - this is not help, this is cynical
  • 19,396 Answers
Hi Auer34.
I am an engineer based in London. The problem you experienced was probably due to the fact that your query has been handled by non-UK based experts.
Tecnik repair service is based on a network of home based engineers. The main offices are based in Salford.
You can get a technician sent at your home within 24 hours by calling
08705 678910. When the automated options ask you to press a button choose " book an engineer" I think it is one. You will be immediately passed to an operator that will ask you model number and post code.
I hope this answer did not sound you too generic, as this is the only way to proceed with Tecnik, unless you want to book a third party generic repairer. In that case I can find any authorized Whirlpool repairer in the area (Tecnik are mainly Whirlpool built).
Please call the number above and let me know if there is any further problem. Do not forget to vote the solution after.
Best regards.
Ginko-UK.
Posted on Jul 06, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. You can contact any of these repair centers for Dishwasher repairs in Nottingham, please click on any of these link:
Technik Dishwasher Repair center
Technik Dishwasher Repair center-2
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 05, 2010
My dishwasher will start its wash progame and get stuck when it pumps the water out and the pump will still run
There is a leakage in the dishwasher and the flood switch triggers during wash. This causes the pump to operate and continue to run as the flood switch remains switched. Best to find the source of leak either from door seal or drain hose.
Jul 31, 2014 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dimensions for tecnik 795/2
This dishwasher was made for tecnik (moben/kitchens direct) by bosch. Any Bosch, Siemens or Neff fully integrated 600mm dishwasher will replace this machine.
Apr 08, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
My Tecnik integrated dishwasher is about 6 years old. It no longer properly cleans the plates. I have cleaned out the two spinning parts to ensure they are not blocked. This has made no difference. It...
It sounds like the pump is not working. I don't know what level of skill you have but before you tackle anything that is a little complicated make sure that you have parts that you can purchase. Then check out the schematics and see whether or not you able to access it. Most of the time you will need to remove most of the working parts.
Lastly I would check out the possible repair bill done by you or a professional and see how much a new dishwasher cost and make a decision. Good Luck
Jan 07, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwasher not pumping out
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 24, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Broken dishwasher?
The dishwaser has a Anti-Flood device (a polystireene block) on the floor of the dishwaser that activates a micro switch if any small amount of water is on the floor of the washer for any reason. This switch automatically puts the washer on PUMP OUT mode and does flash the error mode and does not work. Find out what causes the water on the floor and that will be the reason for not working...
Jan 17, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
No water from top and bottom arm
I'm not familiar with that exact unit. However, all dishwashers use a solenoid valve and pump to either send the water to the drain or to the arms. If the water drains, the pump is good. Check the solenoid valve. It may be jammed (toothpicks and food particles are wonderful) or burned out. If the valve is good and working, your timer is a suspect.
Jun 01, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik dishwasher tkd795/3
your machine has flooded and has trippedthe flood switch in the base of machine which turns on the pump to drain and that is the noise you hear
you will need to find cause of problem which is possible leak in machine
Mar 21, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
