MY COMPUTER SHUTDOWN WHILE IT HAS A 60%REMAINING BATTERY. UNEXPECTED SHUTDOWN. MY LAPTOP CANT RESUME THE PROGRAMS RUNNING AND UNSAVED DOCUMENTS AFTER THE UNEXPECTED SHUTDOWN HAPPENS ..WHY MY OTHER LAPTOP CAN RESUME THE PROGRAMS RUNNING AFTER THE UNEXPECTED SHUTDOWN...IS THERE A SOFTWARE NEEDED TO RESUME THE PROGRAMS AFTER THE UNEXPECTED SHUTDOWN?HOW TO RESUME THE PROGRAMS?
  • Robin ray Derro
    Robin ray Derro Jul 05, 2010
    maybe the battery is the problem because i always use it without unplugging it.....even if it says fully charged i dont unplug it
  • Robin ray Derro
    my laptop is not very hot...i use it in only 10 minutes
  • 304 Answers
If the Computer restarts randomly, then the issue might be due to any damaged Operating System Files.
But, if the Computer shuts down randomly, it is due to the Processor.
All the Processors will be designed in such a way that, if there is any overheating issues, the Computer will shut down randomly.
The overheating might occur due to the malfunction of the Cooling Fan in the Computer.
As this is a overheating issue, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan in the Computer should resolve the issue.
Posted on Jul 05, 2010
    Guru:
  • 366 Answers
To solve it, you should know where the problem lies, battery, adapter, or laptop? so please try 3 ways,
  1. try the battery on other laptop,
  2. try to use a new battery on you laptop,
  3. change a good adapter.
Thanks
How to fix unexpected shutdown due to Blue screen problem of Pavilion HDX9494NR
See if the Check disk utility will solve your problem. To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Mar 31, 2012 | HP Pavilion HDX9494NR Notebook PC
How do I recover from an unexpected shutdown of my laptop?
Most unexpected shutdowns are from thermal signals from the processor or from a memory module failure. Get some cans of compressed air from an office supply store and with all power disconnected and the battery removed, use small bursts of air and blow out all the ventilation frills on the laptop, including all access doors and cd/dvd tray or slot. If it continues after the cleanout, try powering down and removing one memory module and run the laptop. If it dies not shut down, swap out the modules and try again. if it fails, then you know what the problem is.
Jul 07, 2010 | Computers & Internet
Unexpected shutdown..my laptop turns off while it has a remaining 70% of battery and it is not too hot ...how to fix it and what happen?neo empriva m54n
Clean the Air vents and also reseat the RAM modules. This issue may also occur if there is any voltage fluctuation.
Jul 04, 2010 | Computers & Internet
Unexpected shutdown. my computer turns off. it has 100% battery remaining. what is the problem? how to fix it?
how old is your computer?usually the trouble of your computer is in the cooling system..you must clean the path ways of the exhaust of the cooling module and put a new thermal paste on the processor that causes the machine to shutdown by detecting an overheat on the processor,it shutdown automatically to prevent damage to the main board that cause by overheating...kenthbats
Jun 07, 2010 | Computers & Internet
The computer hiberates when I close the lid, then I have to shutdown & restart to resume working. Can I avoid this somehow?
  1. right click your desktop and select properties
  2. select the screen saver tab
  3. at the bottom click the "power" option
  4. deselect the option for hibernation
  5. make sure your hdd is NOT set to turn off when the lid is closed
you can actually set the laptop up to continue running even programs when the lid is closed. this is the best option if you are constantly running application that require an extended wait period between startup and shut-down
good luck and pls rate this post
Mar 23, 2010 | Toshiba Satellite Pro L300 Notebook
I want to remove batterie and work only with adapter until i order a replacment-i have to make sume jumpers-
Dear friend not required any jumper setting. Just remove the battery from laptop then plug in adapter with your laptop. Power on and use. But remember when you use your laptop without battery a sudden power cut may cause of damage of your Operating System & you can not save running unsaved documents.
Thanks.
Feb 05, 2010 | Lenovo 3000 C200 Notebook
Unexpected shutdown with fresh battery ...only cycled 23 times so far. Mac shuts down after about 3 minutes....then shuts down on boot sequence after that. No warning...just shuts down instantly. Macbook...
"Shuts down instantly without warning" is the hallmark of a faulty battery. "All five lights on" is meaningless, as batteries with this fault go from 100% to 0% in a finger-snap. Assuming your battery is under warranty, it should be replaced at no charge.
Nov 08, 2009 | Apple MacBook Pro Notebook
Unexpected shutdown with new battery ...only
This is a duplicate submission -- I will be answering the other copy. Thanks.
Error message
That is an infections that doing that to your computer. You can stop the shutdown by running this command before the countdown reaches zero. Type this command from the Start->Run box:
shutdown -a
This should kill the countdown. However, you will have to get that infection removed from your computer.
Oct 11, 2009 | Microsoft Windows XP Home Edition
Aspire 5630 - Unexpected shutdown!! This weekend, the laptop just shutdown without any warning! I switched it back on, and then after 30 mins, the same issue!!! I checked the battery, and was charging OK....
Depending on the age of the laptop, it could well be overheating. Let it cool down good, and try again. If that is the problem, you will have to clean out the cooling system with a can of air.
DO NOT USE AN AIR COMPRESSOR ! ! !
Mar 16, 2009 | Acer Aspire 5630 Notebook
Computers & Internet Logo
296 people viewed this question
David Payne
David Payne
