Question about Samsung L200 Digital Camera
My Samsung L200 lens wont open despite battery being fully charged
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Try the procedures in this tip.
Posted on Jan 07, 2013
SOURCE: Samsung digimax D103 10 million pixel camera
This error is due to the lens mechanism being jammed and unable to extended, usually due to dirt or grit getting inside. The motor times out and the camera beeps 3 times before shutting down.
If you are unable to have Samsung fix this under warranty, you can carefully prise the lens out using a feeler gauge while powering the camera on, giving the motor a little help.
Posted on Jul 13, 2008
SOURCE: samsung L200 10.2
i have the same camera. u know when its charging when u see the red light on the cord for the camera. when its done charging that red light will turn green =]
Posted on Sep 07, 2008
spotatohead
  • 95 Answers
SOURCE: charging the battery for L200 Samsung
Its on page 13 of the user manual:
http://downloadcenter.samsung.com/content/UM/200810/20081006113527265_L200_English.pdf
Posted on Dec 29, 2008
  • 148 Answers
SOURCE: samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Posted on Apr 02, 2009
lock123
  • 6831 Answers
SOURCE: Samsung PL150 shut down after starting up, lens
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 05, 2010
Despite my samsung L50 camera being fully charged I cant get it to switch on. The blue light flicks on then dies away again with a bleeping noise. I can however view previously taken photos by pressing the...
Here is a website that lists the things to do and check to try to fix this problem:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Mostly this consists of ensuring that the battery is good, and holding a full charge, and also making sure the battery contacts are clean, both on the battery and inside the camera.
As a last thing to check, the switch could be bad. The next web blog talks about another problem the camera could be having, which is a lens "stuck" issue:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Even though it says lens error, it still apllies to stuck lens.
Good luck, and hope this helps.
Oct 31, 2010 | Samsung Digimax L50 Digital Camera
The lens on the Samsung L200 is half way between out and in, also the camera does not switch on however when the power button is pressed, the blue light does show.
Hi
The problem with the lens may be due to dust or due to the problem of aperture (if it was due to this then the solution will be the change of the lens).Else if this due the dust then proper cleaning of camera will solve the problem.
Also make it sure the battery is properly charged.
And if you face any problem then please get back to me.
All the best.
With Regards:-
Subhankar Ghosh
Oct 30, 2010 | Samsung L200 Digital Camera
Wont power on despite being fully charged
Battery is not taking charge. Try buying a new battery, they are usually inexpensive.
Nov 20, 2009 | Samsung Digimax S800 Digital Camera
Charging battery samsung l200
it should be off...and if this will be the first time you're going to charge it, you should charge it for 8 hours straight
Feb 15, 2009 | Samsung L200 Digital Camera
My L200 samsung camara is frozen and the lens are stuck out
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Jan 06, 2009 | Samsung L200 Digital Camera
How can i fix it
Digital cameras are very power hungry. Be sure you have charged battery fully. Other possibility is that the lens got stuck. Maybe you can fix the lens with your fingers, very gently.
Oct 19, 2008 | Samsung L200 Digital Camera
L 100 digital camera is not switching on though the battery is fully charged.
Try removing the battery for a couple of seconds then insert it again. Click on the power button, it should turn on and turn it off again to close the lens.
Oct 17, 2008 | Samsung L200 Digital Camera
Samsung L200 10.2
I called 1-800-samsung, and they sent me a new battery. After the problem insisted, they asked me to ship the camera back to them (still under warranty). The concluded that the cable was defective, and they shipped me a new one within 1 week. That was fast!!!
Aug 20, 2008 | Samsung L200 Digital Camera
Samsung L200 Digital Camera Logo
47 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
