What are the step in solving computer hardware problems ?
    Guru:
  • 366 Answers
I have a best solution to solve computer problems that can solve 70% problem of your system. I am talking about registry easy utility. A Registry easy program is a great ornament for all computer owners, since it helps to keep a computer in perfect working order. It is great for cleaning out the system registry to help the computer run smoothly, and is even great for fixing errors and preventing system registry errors from occurrence in the future. By performing registry easy program on a usual basis, you can make bigger life of your computer and keep it running smooth. I am giving you a link where you can download this software:
http://www.download-registry-cleaners.com/registryeasy/
Posted on Jul 05, 2010
My Pen drive showing 0x8007045d.how solve this problem
Two of the most common causes of I/O (Input/Output) device errors are driver based. Typically, either the device's driver is not enabled or it is out of date. The driver component has an important function, as it acts as a motorlike force that propels USB/plug-and-play hardware into a driving action within the computer. It is the connecting communicating link signaling the CPU to a desired movement. And while not all I/O device error solutions are simplistic, as a good starting point, you can try troubleshooting using a few basic steps, and you might not need to attempt anything else. Access "Control Panel" from the Start menu and then choose "Performance and Maintenance." Click "System" and then go to the Hardware tab and click on "Device Manager." Find the device that is registering an error by expanding the nodes of the appropriate category. If the device has a red "X" on the icon next to its description, the hardware is disabled; proceed to Step 4 to enable it. Otherwise, go to Step 5. Go to the General tab and click "Enable Device" found under the Device Status section; then press "OK." (Note: You may have to follow prompts, as indicated through an enabling device wizard. If you do, continue to click "Next" and follow the prompts until the process has completed.) Test the hardware. If an error is shown, proceed to Step 5. Go to the General tab and click "Troubleshoot" found under the Device Status section then press "OK." Follow the prompts to solve the issue. If an error is still shown, proceed to Step 6. Go to the Driver tab and click "Update Driver." Follow the prompts until the process has completed and then test the hardware.
w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for xp or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Mar 19, 2013 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Tip
Why the CD or DVD doesn't want to run properly?
I will explain to you how to solve this problem steps by steps. First of know that all steps are based on a windows 7 and xp. If you have a different computer version no matter, just try to find the steps I gives below. (These are valuable steps to teach you how to fix the CD/DVD problems).<br /> <br /> Step 1: Turn on your computer<br /> <br /> Step 2: Go to START then open it<br /> <br /> Step 3: Open CONTROL PANEL<br /> <br /> Step 4: Click where says SYSTEM<br /> <br /> Step 5: then a new window will open <br /> <br /> Step 6: Now you have to look for the CD and DVD devices and click on then<br /> <br /> Step 7: And finally on the top bar click on SCAN FOR HARDWARE CHANGES and that's it<br /> <br /> your cd/dvd must be working properly after you have done all of these steps.<br /> <br /> Have a good luck!!!
on Nov 01, 2010 | Computers & Internet
Bsod
Computer blue screen of death is usually related to hardware or driver. It is typically caused by software errors in device drivers: in Windows systems by poorly written device drive . They can also be caused by physical hardware faults, such as faulty RAM memory or power supplies, overheating of components, or hardware which is run beyond its specification limits . On the other hand, registry damage,corrupted program and viruses are the major causes of computer blue screen,too. According to the issue you've got, the following tips may be available to you.1.An efficiency troubleshooting step on hardware is to start your computer with the minimum hardware necessary to run the operating system. If your computer starts successfully it proves that one of the removed hardware devices was the cause of the STOP message. Otherwise move to the next solution.
2.Boot your computer in Safe Mode by pressing F8 at startup. Then go to My Computer and right-click on Disk C to select Properties from the dropdown menu. From the Tools tab, perform an error check and disk cleaning. 3.If the about two solutions doesn't work, the last one I can suggest you is to create a bootable disk. It is the most quick and effective way for you to solve the problem. You just need to download a software such as TenorshareWindows Boot Genius. It owns a better performance among all kinds of software I've used. Windows Boot Genius is a multiple windows repair tool which can be used to fix all computer errors, create bootable CD/USB, recover data lost and unlock windows password, etc.It is as easy as three steps to fix your computer by use the software:Step 1. Create a bootable usb or cd by this software
Step 2.Set your computer boot from CD or usb flash drive
Step 3.Fix computer blue screen after running up Windows Boot Genius
By the way,reinstall your operating system can also help you out if nothing important stores in it.
http://www.windowspasswordsrecovery.com/fix-windows/blue-screen-of-death.html
Mar 03, 2013 | Acer Aspire Computers & Internet
I have a thoshiba satelite a100 laptop my problem is usb device is not working i format the laptop and then install windows xp sp3 but not solve this problem i conect any usb device then erormessege is...
To work around the above issues, one of the below solutions could prove helpful:usb-device-not-recognized.jpg
  • Unsecure or Loose Connection
    Unplug the presently connected USB device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a USB device.
  • Scan for Hardware Changes in Device Manager
    Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the USB device.
  • USB Hub Power Management
    Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps; Click Start, and then click Run. Type devmgmt.msc in the popup box, and then click Ok. Expand the Universal Serial Bus Controllers' node, and then follow these steps for each USB Root Hub that is listed.
    1. Right-click the USB Root Hub and then click Properties.
    2. Click the Power Management tab.
    3. Click to clear the Allow the computer to turn off this device to save power check box, and then click Ok.
    Note: If you perform the following p
      Unplug the presently connected usb device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a usb device.
      Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the usb device.
    • usb Power Management
      Note: If you perform the following procedure on a laptop computer, you may reduce the battery life.
    Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert.
Mar 28, 2011 | Computers & Internet
Can't write cd's
I will explain to you how to solve this problem steps by steps. First of know that all steps are based on a windows 7 and xp. If you have a different computer version no matter, just try to find the steps I gives below. (These are valuable steps to teach you how to fix the CD/DVD problems). Step 1: Turn on your computer Step 2: Go to START then open it Step 3: Open CONTROL PANEL Step 4: Click where says SYSTEM Step 5: then a new window will open Step 6: Now you have to look for the CD and DVD devices and click on then Step 7: And finally on the top bar click on SCAN FOR HARDWARE CHANGES and that's it your cd/dvd must be working properly after you have done all of these steps. Have a good luck!!!
Nov 01, 2010 | Lite On XJ-HD166S Internal DVD Drive
Usb port not recognized any device
  • Don't worry just follow the simple steps and get rid out of that problem
  • Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 29, 2010 | Acer Veriton 7600GT PC Desktop
How do i get the Audio to work?
  1. Check the volume control located on the front or side of your computer to be sure that it is not set at the lowest level. If the problem is not resolved, proceed to Step 2.
  2. Step 2 Right-click on the "Volume Control" icon located on the Start menu taskbar and then select "Open Volume Control."
  3. Step 3 Remove all checkmarks beside "Mute" in the Master Volume and all other visible categories. If the sound problem is not solved, proceed to Step 4.
  4. Step 4 Right-click on the "Volume Control" icon and select "Adjust Audio Properties."
  5. Step 5 Go to the Volume tab and adjust the "Device Volume" by moving the slider within the range from Low to High.
  6. Step 6 Click on "Speaker Volume" under Speaker Settings and move the slider within the range from Low to High to reset the left and right speaker volume. If the sound problem is not solved, proceed to Step 7.
  7. Step 7 Go to the Hardware tab and highlight the device with the sound issue and then click "Troubleshoot." Follow the prompts until the issue is resolved.
Mar 02, 2010 | Computers & Internet
Ive got a hp compaq lappy nly 6 months old.but the
check whether your audio driver is properly installed or not...to check that right click my computer and then 'properties'...and then select hardware tab and choose device manager...in that check 'sound,audio and game controllers' carrying any marks..if it is its a software problem..it can be solved by installing a proper driver to it...if these are not means its a hardware problem....first check the above steps and come to a conclusion.....
is this cleared your problem?
Jul 15, 2009 | HP Compaq Computer Speakers
Problem motherboard driver
hi buddy!
be sure your sound & video display is installed heres a few step
right click My Computer then Properties then click Hardware & device Manager if you see your sound and video card have a color yellow means not install ok
Jun 24, 2008 | Computers & Internet
Hardware not detected
well..that's quite a few items to be invisible to your bios..sounds like a moderate to severe corruption issue..
i recommend a full re installation of the core driver set, which should be on a cd that came with the computer when purchased.
Mar 27, 2008 | Acer Aspire 3680 Laptop
Computers & Internet Logo
103 people viewed this question
David Payne
David Payne
