SOURCE: drip pan is overflowing, ice maker works, no water
is not the filter water line frozen in refrigerator or water valve check and see if refrigerator door (ajar)
lift the bar up to shut the maker offf and then turn it bakck on and wait.
SOURCE: whirlpool stopped making ice, water side is fine.
Hi!
Please check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: Whirlpool Gold Side by Side Ice maker not making ice.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze. You can take the water
line off the valve and watch to see if it drips.
