Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Paper jam - 15 sheets fed through at once - Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
  • pat4362 Jul 05, 2010
    15 sheets was the total number of sheets in the feed tray, it took it all
  • 518 Answers
Has to be too much paper in feed tray
Posted on Jul 05, 2010
T652n 202.03 paperjam
1Open the upper-front cover and remove the toner cartridge.2
Look into the printer. Remove any jammed sheets of paper that you find there.
  • If the print job only consisted of this one page, reinstall the toner cartridge and close the front cover. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If the print job consisted of more than one page, confirm the entire paper path is clear before printing again. Do the following:
    1. Remove the top paper tray ('Tray 1').
    2. Remove any jammed or partially-fed sheets of paper you find here, then reinstall the tray.
    3. Go around to the back of the machine and open the upper-rear cover. Remove any jammed sheets of paper you find, then close the cover.
    4. Once you have confirmed that the entire paper path is clear, reinstall the toner cartridge and close the front cover.
    5. Press the pattlnk_10162008_2247-select_button.jpg button to clear the error, and then try printing again.
  • If you cannot locate any jammed paper under the toner cartridge, then check the rest of the printer for any jammed paper. Do the following:
    • Remove the top paper tray ('Tray 1') and look for any jammed or partially-fed sheets of paper.
    • If you do not find any jammed pages there, reinstall the tray and go around to the back of the machine. Open the upper-rear cover and look there.
    • If the entire paper path appears to be clear, close the rear cover and power off the printer. Reinstall the toner cartridge and close the front cover. Power the printer back on. If a 200 error continues on power up, a sensor in the printer may be malfunctioning. This will require a service call to correct the issue. Please contact Lexmark Technical Support for additional information (see Contacting Lexmark Technical Supportbelow for details).
Aug 28, 2012 | Lexmark T652N PRINTER OPPENHEIMER SPECIAL...
Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Sep 09, 2008 | Minolta magicolor 2350 Laser Printer
Paper jam - I can see the jam, but don't know how to remove the paper.
Hello
Open the top cover of the printer.
If you can see the jammed paper, take one or more sheets of paper and pull them toward you.
While pulling the paper, press the RESUME button to turn the paper feed rollers.
If the paper needs to be fed in the opposite direction, release the RESUME button and then press it again.
If the paper is still jammed, turn the printer off or remove the power cord from the printer. Then turn the printer back on or plug the power cord in.
The printer will run through a reset cycle, which may clear the paper jam.
If the paper is still jammed or if several (8 to 10) sheets are jammed, take hold of a sheet in the middle of the stack using both hands.
With firm, even pressure, pull the sheet toward you.
Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
Make sure no scraps of paper are left in the printer.
Close the top cover of the printer.
Try printing again.
Apr 16, 2011 | HP PSC 750 All-In-One InkJet Printer
How do i set it to print 11x17. It jams everytime and will not print to that size
Hello :-)
Please open the paper supply tray you wish to use. At the very front of the tray, to the right, you will see a blue dial. This dial is used to tell the copier what size paper it can expect to be fed. You can put many sizes of paper in the tray, but the blue dial MUST match the size that truly is in the tray. If ,for example, the blue dial is set at "LETTER" but the paper in the tray is 11x17, the copier will look at the dial setting and expect the paper to have passed its paper path sensors in a certain amount of time. So if the dial says 8.5x11 and the actual sheet of paper fed just keeps on moving by the sensors (11x17) the copier freaks and treats it as a paper jam assuming it has fed multiple sheets. Happy New Year to you and yours! :-)
Jan 19, 2011 | Canon ImageRunner 3025 Black and White...
Paper is jammed
Firts remove the back panel by turning the large knowb in the center. Then if more than 2 pages are stuck inside "gently" pull on all the sheets except the top and bottom ones. They should pull out with moderate resistance. Once thos sheets are ou do the same thing with the remaining two sheets.
NOTE: when a printer is powered on with paper already in the paper path it will usually try to eject them by turning its rollers.
NOTE: some older HP DeskJets when you press the paper feed button (with paper already in printer) it will move the paper in one direction and when you press again it will move the paper in the opposite direction.
Apr 14, 2010 | HP DeskJet 845c Printer
While printing with OKI C5600 very often error message pops up about jammed paper though no REAL jam happened. To solve I just open and close paper tray and front door. JAM PAPER error is real pain if...
Have you tried cleaning the paper feed roller(s)? Either soap & water OR isopropyl alchohol with a cotton ball will do, just make sure the rollers are dry before trying to print again, otherwise damage to imaging unit (drum/toner unit) could occurr. If the printer doesn't feed in the first place, the printer thinks it has a jammed paper, thus opening paper tray and front cover resets misfeed/ jam condition. Let me know your progress....Tim
Oct 24, 2009 | OKI C5500n Printer
Won't photocopy / warning light flashing /
The paper feed system is worn (rollers, and separation pad). What is happening, is extra sheets are being fed into the machine primarily because the separation unit is not doing it's job properly. So rather than just one page at a time being fed, it is allowing an extra sheet to "creep" in intermittently, causing the jam. And the indicator you are seeing is the "jam" indicator.
Jul 16, 2009 | Canon PC170 Copier
My printer jammed and now it won't start at all
My 1220C printer jammed I got the paper out by pulling and now it won't turn on for printing
Apr 15, 2009 | HP DeskJet 1220c InkJet Printer
Paper Jam Errors
switch off power to printer and switch on again, worked for me
Jan 14, 2008 | Dell 3100cn Laser Printer
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
76 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
