Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Engine runs ok until the blades are engaged, if I take the plug wire off the left side, it has no effect on the engine running.I changed plugs and checked the coil and wire, it has fire and compression. If I take the wire off the right side the engine dies. I did not check the carb, although the plug in the dead cyl shows some gas on it.
  • rdb_wp Jul 05, 2010
    I should have added that the engine still runs, but at about half power
  • 6,826 Answers
Try to determine if the safety switch on the seat is closing or opening.
Does this happen when you are sitting on the seat and engage the blades?
You're ight, if you have gas and spark it should run, if the mixture is right.
Good luck on this one.
Posted on Jul 05, 2010
  • Duane Wong
    Duane Wong Jul 13, 2010
    If the plug shows gas in it that is not firing, it could be a bad plug wire, and less likely a pluig that is bad. Or the coil is bad, and not giving full high voltage to the plug through a possible good wire.
    Replace the plug and wire in the offending cylinder to determine if this is the problem (ignition problem).
    Good luck.
You may have a bent push rod. I had the same problem and started tearing the engine apart. When I took off the valve cover on the left side(sitting in the seat)the push rod was just laying there.
Posted on Jul 13, 2010
After I changed the blade my TB 554 edger won't start
you have flooded the motor..
remove the spark plug.. lay it aside.. pull the rope until you can't pull any more (you are trying to "clear/clean out" the engine) ... You may have fouled the spark plug too... take your old plug and go to Wal-mart..or the local parts store.. get a new one.. and it should run.
Jul 08, 2017 | GAS Motorcycles
Engine seems to run fine but when pto is engaged engine loses power
whatever the pto is hooked to,is putting pressure on it and slowing it down,if its a deck,then the spindles are bad or binding,blades need to turn freely
Jul 11, 2015 | Garden
Engine locked up while changing the blade and mower leaned over carb side was up it will not move either direction
blade brake is engaged unhook it and try turning the blade by hand should work
Aug 14, 2014 | Toro Garden
John Deere 17 horsepower Kawasaki engine won't run WOT when blades are engaded
swap the coil with the other side and see if that plug gets sooty instead of the one that has been
May 27, 2012 | Garden
Runs fine when blades not engaged, engaging blades causes engine speed to be reduced. Engine speed increases to normal when blades not engaged, or when motor not moving. Sounds as if mowing through very...
If it has a B&S engine, and many do, try this. Remove one spark plug at a time and start the engine. If it runs with one plug, but not the other, then you have a dead cylinder. That is why it seems to run OK so long as no load is on it.
I have had 2 different mowers with B&S engines which bent the valve push rods on the left (as the driver sits) side of the engine causing the problem you speak of. And if you google this issue you will find that I am not the only person who ever had this scenario.
If you have the OHV type engine you can pull off the little valve cover, next to the spark plug, and see the rocker arms and the push rods behind them. Replacing them is about as easy as it looks, however setting the gap between the top of the valve and the rocker is best left to someone who knows what they are doing.
Sep 10, 2011 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
My LGT 2554 Husgvarna mower engine tends to die when the mower blades are engaged. When the engine runs with the blades off at low idle it is ok. When you advance the throttle fast to full it loses power...
A common problem on the 21 & 23HP models is bent valve push rods on one cylinder. With this the engine runs and seems fine, albeit a bit quieter, until you put a load on it like engaging the blades which causes it to nearly die. So you may want to eliminate this as a possibility by running the engine with one plug wire removed and then the other. If it runs with one wire on alone, but not with the other wire on alone, then you have a nonworking cylinder even though it is receiving spark. Just a thought.
Jul 30, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Engine starts and runs okay until I engage blade
I had the same problem on a 21HP, you are running on one cylinder. Take off the valve cover and most likely you will have a/some bent valve push rod(s) which is common on B&S V2 engines. They are cheap to buy but kind of tricky to install and properly adjust.
Jul 06, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have Briggs 18.5 horse and after I mow for a while the motor will bog down and quit unless I dis-engage the blades. I removed the spark plug and it looks wet. I replaced it and after a short time again...
If the engine runs ok when the blades are not
engaged then the engine is all right. Maybe its a faulty safety blade switch or a wire to the switch is stripped and is earthing to the body. Stephen
Sep 04, 2009 | Garden
Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
Mar 15, 2009 | Garden
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
634 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
