When I turn off 2 channel power amplifier 1 channel makes a wierd sqeal sound for about 2 seconds
  • Audio Player... Master
  • 5,158 Answers
The only thing I can think of that would have this effect is an Electolytic Capacitor in the Audio Output Stage. Maybe one of the ones that connect to the speaker. It may be leaking the voltage after power down.
Posted on Jul 06, 2010
My Peavey Mark 3 400 CHANNEL 1 does not put out sound. When you turn the pre gain it will cut in for a sec then out. Channel 2 is good. I checked the readings on the pre gain pot on channel 1 and 2 and...
Transfer Channel 2 speakers to Channel 1 to check if it does put out a sound. If it does, it means that your Channel 2 amplifier is defective. However, if it doesn't,
then your Channel 2 speaker is defective. So, have this checked to find out the result. Defective items needs replacement or be repaired. Send us your e-mail for the result so we can further extend our assistance.
Oct 13, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
I cannot find the specs or user manual on the JVC archived items list. A few sites want to charge $10.00 for the user guide info, but I think that is too much to charge.
Defiantely not 200 watts
KS-A82
  • 2 Channel Amplifier
  • Bridgeable 2 channel amplifier
  • Output power: 25W x 2, 20 - 40,000 hz at .08 THD
  • 2 ohm stable
  • Adjustable gain (.1 - 2v)
  • MOS-FET DC-DC converter
  • Multi phase connection
  • 1 Pair of line input terminals
  • Remote relay turn on system
  • MSRP: $159.95
http://www.admtechusa.com/JVC.html#KS-A82
May 22, 2009 | Car Audio & Video
Channel 2 crackles
Make sure your speaker wiring does not come close to the 12v power cable running for your amplifier. If your amplifier's 12v power cable runs on the drivers side of the vehicle, run your speaker cables on the passengers side and make sure your tweeters have a high pass filter to stop any pickup of engine sound (When you are driving you *WILL* notice it at high RPM. a HPF (High Pass Filter) will also stop those nasty hissing sounds on S's.
Feb 11, 2009 | Alpine PDX-4.100 Car Audio Amplifier
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Improper function
try hooking up your subwoofers in series. then connecting them bridged to the amplifier. as follows: positive from sub#1 into positive of amplifier left channel.. negative sub#1 into positive sub#2. negative sub#2 into negative amplifier right channel. turn the gain down as this will sound pretty loud.
Jul 13, 2008 | Pioneer Car Amplifier GM-5100T - 2CH 760...
QSC 2450 Power amplifier
i have a pyle pro 1000 watt max 2 channel mono and 2 channel stereo and when i get that thing loud the little red light cums on basically what i mean is that the amp on channel one is cooked i myself i wouldn't even use it y cause more damage
Apr 03, 2008 | QSC RMX-2450 Car Audio Amplifier
No sound
check your speaker wire, or may be you have a shorted speaker. disconnect all speaker before you turn on your amplifier again.
Jan 20, 2008 | Crown CE2000 2-Channel Amplifier
Rockford T10001bd: Capacitor buzzing
If the top is split open, it has vented electrolyte. This is most commonly caused by more serious problems in an amp. Do the other adjacent caps show any signs of damage?
Is it blowing fuses? Connect a 20 amp fuse in-line with the B+ line of the amp. If it blows the fuse, the amp is drawing excessive current and most likely has more serious damage than the single vented cap.
Dec 04, 2007 | Rockford Fosgate T10001BD- Car Audio...
Amp
Make sure the amplifier is turning on. Remember ther is three wires that power the amp Battery constant, Ground which in a fiberglass boat run ground to battery not motor, Plus make sure the remote wire is hooked to power, generally it is switched power. But if the amp is not turning on temporarily hook remote and power together to battery and see if the amplifier turs on. Second be sure you have a good set of RCA cables hooking the radio to the amp. And finally check and make sure the gain is turned up on the amplifier.
Aug 31, 2006 | Dual 2-Channel Bridgeable MOSFET Amplifier...
23 people viewed this question
 Grubhead
Grubhead
