Question about Brother IntelliFAX 4750 Plain Paper Laser Fax
Brother Fax 4750 System error 76
My fax machine got seystem error 76 when turn on What is this error related with? Brother Laser Fax 4750
  • Anonymous Mar 19, 2014
    error messages 1930
  • Anonymous Mar 28, 2014
    when i fax something on my brother machine it shows up blank on the other end
  • 47 Answers
Try resetting the machine by pushing the features button, and then *2864 in quick succesion, if done correctly you will enter test mode, then enter 91, and then after that clears enter 99 to exit test mode. make a copy to see if it works, and if it doesn't it is time to replace the fixing assy.
Posted on May 12, 2008
Error Code 77 on brother 4100 fax intelifox business class
( 76 Heater harness disconnected or broken. Or heater thermistor harness
disconnected or broken when the power is turned on, the front cover is
opened and closed, or the machine exits from the sleep mode. )
( 77 Power turned off and on at the occurrence of error 76 or 78. )
( 78 Heater thermistor short-circuited. Or heater thermistor harness disconnected
or broken when the machine is on standby. )
Nov 05, 2010 | Brother IntelliFAX 4100 Laser Fax
My Brother 4750e promted: Machine Erroe 71 unplug machine and call service
that error code points to your laser unit and unfortunately for you will require a tech.
razors
Mar 28, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother 4750e fax machine
1- check the small stip of glass and see if it has toner,
check the maintenance section of the manual (it's free, just register)
http://www.retrevo.com/support/Brother-4750-Fax-Machines-manual/id/19095ci557/t/2/
Aug 04, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Machine error 78 offline
You have a bad FUSER. There's nothing you can do. A dealer must replace the fuser.
Jun 26, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Machine error 76 for brother fax 4750
The error is related to the fuser assembly overheating. The only course of action you could take would be to turn off the machine for an hour or so to give the memory time to reset. If that does not resolve the problem, then the fuser assembly needs replacement (Part# LJ7759001). This should be replace by a certified tech.
Hope this helps!
May 21, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Laser fax 4750
look in back of the fax, it probably has a parralel plug, if yes just plug in and voila( may have to download driver from brother)
Jan 22, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother 4750 fuser replacement
The entire front, sides, and rear cover is all one piece. Take the screws out and lift straight up.
Dec 14, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother IntelliFAX 4750 Plain Paper Laser Fax Logo
1,220 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
