Question about Acer TravelMate 4233 UWLMI (ACN9678) PC Notebook
Removing back cover of Acer TravelMate 4233 UWLMI
How to remove back cover of Acer TravelMate 4233 UWLMI PC Notebook after having removed all holding screws.
SOURCE: Replacing RAM chip in a acer aspire 3000
I found the user manual at http://www.synapsenow.com/synapse/data/7117/documents/AS3000-5000_UG_ENG.pdf Page 63 of the acer user manual listed these steps for changing the memory: "1 Turn off the computer, unplug the AC adaptor (if connected) and remove the battery pack. Then turn the computer over to access its base. 2 Remove the screws from the memory cover; then lift up and remove the memory cover. 3 (a) Insert the memory module diagonally into the slot, then (b) gently press it down until it clicks into place. 4 Replace the memory cover and secure it with the screw. 5 Reinstall the battery pack, and reconnect the AC adaptor. 6 Turn on the computer. The computer automatically detects and reconfigures the total memory"
Posted on Sep 02, 2007
SOURCE: remove cd/dvd drive acer travelmate 2310
The standard drive in the 2310 seems to be a Matshita U3-840D, which is a basically a piece of rubbish. I did what paella recommended, and the drive pulled out without much trouble, but has a small plastic flap attachment at the back which is evidentally a panel for the screw which holds the drive in place (this was split when I pulled out the drive... which makes me wonder whether a replacement will be all that easy to push in without opening up the entire unit and removing, then replacing, the existing screw. I'd recommend opening the laptop first if possible, and removing the screw at the back of the drive which keeps it in place before pulling it out.
Posted on Nov 20, 2008
SOURCE: Removing cover on Acer 5720z to access RAM
the force pulling the cover of the memory, without fear, I worked that way.
Posted on Jan 28, 2009
leecom72
  • 4806 Answers
SOURCE: Acer travelmate 4650, after bios flashing, no display.thanks.
HI there
Sounds like the bios flash has failed, the only thing you can do now is try to flash again, make sure you have the right bios update for that model machine, suggest you get a USB floppy drive so you are able to re-flash the bios, if it still doesn't work then the machine is rendered useless.
Good luck and thanks for using Fixya!!!
Posted on Feb 11, 2009
paulrelliott
  • 69 Answers
SOURCE: acer travelmate 2410 hinges broke on cover how to
Very carefully, 1-push the screen right back holing the hinges where tey should be, 2-you have to unclip the black panel (over the power button) using an old credit card so yo dont damage the plastic, as this panel loops over the hinges & can only be removed with the screen right back, BUT remember to be carefull as the cables run through the blak covers & you don't want to snag them!
I've done this before so don't be afraid to pull hard start at the edges & make sure when aclip releases not to carry on pulling (use your thumb on the base of the comuter whilst pulling, dont just rip em off as you'll crack the panel quite easy.
but first I'd see if you can get replacements they're only aluminium angle plates with 2 screws holding them to the base.
Hope tis helps!
Posted on Sep 22, 2009
Testimonial: "yes very helpful thanks alot"
Recover acer travelmate 2480 password
Try removing the main battery and unplug the power, then hold the power on button down for 30 seconds, if this does not work, remove the cmos battery for 30 seconds to reset the bios
Dec 24, 2013 | Acer TravelMate 2480 Notebook
Overheat on acer travelmate 2300
This problem happens mainly due to the thermal unit being obstructed by dust.
Please follow the below steps to solve this problem.
Remove the Thermal module
1. Remove the 2 screws holding the IO Bezel
2. Then remove the IO Bezel
3. Remove the two screws securing the heatsink cover
4. Remove the heatsink cover from the main unit.
5. Disconnect the fan cable
6. Remove the four screws that secure the thermal module.
7. Pull the thermal module outwards and remove it.
Note: The edge of the thermal module is very sharp. So be careful when when removing it.
Once the above steps are over, make sure to clean the thermal module and remove every dust found inside there.
after cleaning, make sure that the vents are not obstructed and then follow the above instructions in the reverse order to replace thermal module.
Hope this helps.
Jul 06, 2011 | Acer TravelMate 2300 Notebook
Acer 507DX Travelmate, need to remove cover/case to install new HD, apart from the dozen or so screws in the bottom, what else holds it?
The hard drive is usually located under a recess plate on the base of the laptop.
If you locate the battery on the underside, the hard drive cover is next to it and is held on with just two screws.
Hope this helps.
Oct 25, 2010 | Acer TravelMate 507T Notebook
Where is the cmos battery situated on my acer travelmate 202T . Thanks
acer laptops differ with every model but it will be in one of two places. first place to look is under all the removable covers on the bottom of the laptop. if you can't see it after doing this then you will have to take the keyboard off and it will be under there. the screws for removing the keyboard are marked on the under side of the laptop. hope you get it replaced and every thing will be ok. please let me knoe how you get on.
Aug 10, 2010 | Acer TravelMate 202T Notebook
Looking for visuals to assist me in removing my harddrive-below
verry eassy to do turn laptop over remover cover from hardrive there will be screws holding hardrive in place remove them, push hardrive back till it stidesout of socket and lift it out.i run acers do it all the time. your hardrive cover on bckside will be aboyt 4 inchs long about 3 wide a couplescrews holding it in place.IM me you need assistance ok glad to help
Jun 29, 2009 | Acer TravelMate 2423WXCi Notebook
BOOT UP AND BIOS PASSWORD REMOVING
you have to open the back cover and there you can find  a CMOS battery located on the motherboard ....try to remove  and insert it ..it will reset the BIOS password ...
May 10, 2009 | Acer TravelMate 240 Notebook
Keyboard removal on a TravelMate 512DX PC Notebook
The battery could not be fished out afer removing the memory expansion door?
Jan 19, 2009 | Acer TravelMate 512DX Notebook
Removal of an Optical Drive
for model TM4151,
1. you need to open the power cover (power cover is cover where power button is).
2. remove screw that hold keyboard.
3. after you remove keyboard, you will see the screw that hold dvd (it's under keyboard)
Aug 23, 2008 | Acer TravelMate 2300 Notebook
Removing the back cover
I think you have to remove the screen assembly first - I will check and let you know.
Mar 21, 2008 | Acer TravelMate 240 Notebook
Removing middle cover
If you are positive that there are not any screws holding it down then look for tiny plastic tabs holding in place. I usually use a very small flat head screw driver and find an area to safely insert the tip between the cover and the rest of the laptop and very gently and slowly separate the two. If you come across an area that just won't move then look for something that is securing it.
PATIENCE is the biggest key. I learned this the hard way on my own laptop, lol!
Good luck, n hope this helps!
Nov 28, 2007 | Acer TravelMate 2702WLMi Notebook
Acer TravelMate 4233 UWLMI (ACN9678) PC Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
