Question about Canon EF 35-350 F3.5-5.6 IS USM Lens
How do make the push / pull zoom action smoother on a canon 35-350 lens?
    Brigadier General:
  • 3,006 Answers
There's nothing you can do without stripping the lens down: definitely not a DIY job on your lens!
Barring any actual faults, the smoothness is determined by a number a factors such as how well the components were originally machined, how well the lubricants are distributed internally and the condition of internal bushings. Even the pneumatic action of air entering and escaping the lens as it's zoomed can have an effect.
In practice, new lenses may need a bit of breaking in to become fully smooth, lenses which are not often used will tend to lose their smoothness as inactivity allows internal lubricant films to dry out. I've also found that superzooms such as yours have so many elements moving around inside that it's difficult to find a truly smooth one unless upgrading to a professional grade lens.
If there's anything in the motion which is definitely notchy or catching then there is a fault and the lens will need professional attention, but if the lens is still fully usable then you might decide to live with the fault whilst saving for a replacement lens as labour costs alone will make you wince.
Sorry not to be able to offer anything more positive, but not everything is a quick and easy fix.
Posted on Jul 05, 2010
How to fix stuck zoom lens?
Geeeeently, pull it out by the end of the lens until it clicks in plase. Never push it in!!!
Jul 18, 2014 | Canon Cameras
I accidentally pushed my lens in while taking a picture so now when the camera thinks it at no zoom it has a 24 zoom (number on lens) How do I fix?
Hi and welcome to FixYa!
This problem does occur. As a first course of action I strongly suggest that you remove the battery of the camera and turn the switch on for 10secs. while the battery is removed. After 10secs. insert the battery then turn the camera on. This should reset the system and may get your camera back to it's normal operation.
Hope this helps and thank you for using FixYa! Have a good one!
Jan 15, 2011 | Canon PowerShot SX30 IS Digital Camera
Lens Error. I didn't do anything to my Canon Powershot A1100 and now I have a lens error that will not go away. My lens is completely zoomed in and won't move. Help!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
May 03, 2010 | Canon PowerShot A1100 IS Digital Camera
No lens lock on a Sigma 135-400DG, falls to full extension.
buy the glass that does not zoom via push pull - When they get old and sometimes right off the shelf new the push pull zooms get loose - the only fix is for you to have it serviced and even then it is a temporary fix as the very nature of what you do to use the zoom will ultimately cause the same problem to occur.
Apr 21, 2010 | Sigma Zoom Telephoto 135-400mm f/4.5-5.6...
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Canon EF-S 17-85mm - Stuck Zoom
this lens has a design shortcoming in it's aperture's ribbon cable ,the cable will rupture after around 1 year using, this problem taken place in more than 60% of owners with this lens. Canon has no respons with it problem and ask you send to their quick fix store for repair.
Jul 05, 2009 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
My question is about a Quantaray 75mm-300mm
Slide a piece of paper partway under the ring (make sure you leave enough hanging out so you can remove it later) and see if that tightens the action some.
Another low-tech approach is to push the ring to expose the inner barrel, then attack one or more pieces of Scotch tape or masking tape.
Jul 30, 2008 | Quantaray 28-200MM F3.8-5.6 Lens for Canon...
Blurred night time football pictures
The standard canon 75-300 lens is not considered a "fast" lens. Because of this, when zooming in on objects you are actually reducing the amount of light hitting the image sensor. Fast lenses cost $$$$. Just google "Canon L Glass" and you will see what I'm talking about. Try opening the field of view (zooming out) to allow more light to be absorbed bu the image senor. Crop your subject later in whatever software you use. You can also use one of the manual modes and up your f-stop to make the camera more sensitive to low-light conditions (higher f-stop means higher film speed.. higher film speed is how fast the "film"... aka image sensor absorbs the light. for action photos, faster film speed is key!!). have fun experimenting.
Sep 26, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Blurred football pictures
low light means the shutter stays open longer to capture the image.   Try changing exposure settings.
Sep 30, 2006 | Canon Digital Rebel XT / EOS 350D Digital...
Canon EF 35-350 F3.5-5.6 IS USM Lens Logo
191 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
