Question about Nokia 6303 Cell Phone
Mic is not working - Nokia 6303 Cell Phone
  • Nokia Master
  • 17,129 Answers
Pen the phone and clean up the holes near the mic, if this wont clear the fault, then check for the continuity of the mic using a multimeter, unless you are tech savvy do not attempt to replace, but it is safe to check this out with your friendly service shop nearby, keeping this in mind if this seems to be the problem then the service cos t will be minimum. so go one with tip in your mind. good day.
Posted on Jul 05, 2010
Headphones are working and mic is not working
The mics are of two types: electrostatic(cheap and modern) and old-stiled "dynamic". Old souncards were automatically switching to the mics type. Modern soundcards have to be switched manually.
In "sound properties" you first must check in that mic is turned on, mic volume in max and in all menues avd buttons find something like "mic amplifier boost"and turn it on. It's only non-standart mic tuning option in standart systems. All other problems in defects. Soundcards can be verifyed by so:
(with maximal speaker and mic volume) many times plug in and plug out any reacheable mics and headphones to the mic connection nest (hole), and listen(or recording) resulting scratches. If scratches or other related sounds are abscend(only noise), soundcard is bad. The mic problem may be in "jack left-right interconnection". This useful thing may hang some improper cards. Also that cards often cannot work with dynamic type. And they very sensitive to a manufacturer, and model of mic.
Problem may be also in configuring multimode speaker nests in 5_1(7.1) cards like REALTEC - the mic nest may be switched to the speaker output mode. Open Realtec's control center(in control panel or quicklaunch icon) and check in mic nest to "mic mode" or switch mode from 5.1 to stereo speakers.
May 17, 2011 | Computers & Internet
I hav a microphone problem.Its working properly on my pc,but when when i connect it to my social netwoking site it doesnt work properly,some wired noice comes out th speaker of th one who is listning to my...
Go on mic. configuration and select on microphone use from configuration mic. name and test the mic. On test mic not works mic,is posible to need a driver for mic and need download and install the driver.
Jul 30, 2010 | Computers & Internet
Mic not working (plantonics headset)
Your exterior mic MAY have been the one ACTUALLY working rather than the one on the headset. Some mics require a battery for the mic part to work, Not sure about your particular Plantronics. If it has a battery, then check the battery as the receiver part does not use it but the mic MAY use it.
Oct 06, 2009 | Plantronics Radio Communications
Hp pavillion dv6000 headphone mics don't work, external mics work
check external mic in another system.
update the bios of the sytem.
update drivers of sound cards
Apr 11, 2009 | HP Pavilion dv6000z Notebook
Motorola v3i mic not work
better to replace ur mic in your v3i if its not working.....put mic from another v3i...
Feb 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
PS3 American idol encore 2 mic problem
I GOT THIS TO WORK.
First, make sure ur PS3 system update is full updated.
1) Turn on PS3
2) make sure all the mics were unplugged
3) plug one mic in
4) accessories setting -> audio device
5) select logitech as input
6) plug in the second mic
7) accessories setting -> audio device
8) scroll thru the input device, make sure it lists both logitech, this makes both mics are sync'ed to ur PS3
9) select the FIRST logitech device in input device
10) save setting, restart ur PS3
11) start the game as usual
12) in duet mode, both mics should show, if one is working and the second one doesn't, one forum suggests that u unplug the one that works and replug it while u are still in the menu.
Works for me, I hope it works for you. Cheers.
Jan 01, 2009 | Konami Karaoke Revolution: American Idol...
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Mic
first u check whether your mic is correct, try to plugin some other pc where mic is working in good condition,
if the new mic is working properly on another pc then
Re install your sound card Driver, and try
Cheers
Nov 30, 2007 | Philips SPC 200NC Webcam
Nokia 6303 Cell Phone Logo
98 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
