Question about Dynex DXWEGRTR Router
I don't see the network I named on the list of wireless networks.
I can't change the the network for unsecured to secured.
    Novelist:
  • 112 Answers
Please follow the steps mentioned below to secure the Wireless Network.
  • Please open the Web browser, type 192.168.2.1 and press enter.
  • Please enter the User Name "admin" and leave the password blank.
  • Please click on Wireless section and click Security.
  • Now, you can pickup any of the Wireless Security like WEP, WPA, WPA2 etc.
  • Select the Wireless Security encryption type and save the settings.
  • The Wireless is secured now.
  • You can also refer page #12 for the information.
http://www.dynexsupport.com/sites/dynex/dl/DX-WGRTR_07-365_Final%20CD.pdf
Good Luck.
Thank you for contacting.
Posted on Jul 05, 2010
I have created too many wireless networks and only one is secure. i want to delete the unsecured ones and change the password on the secure ones.
To Remove the other Networks
XP :::
Goto control Panel -> Network Connections
Right Click the Wireless network connection and select Properties
Click on the wireless networks tab ( Top )
Under Preferred Networks you can find the names
Remove them and click OK
Windows Vista /Windows 7
Open Control Panel
Goto Network and Internet -> Network and Sharing Center
On the left under Tasks Click Manage Wireless Networks
You Can Remove the names by right clicking on them and Remove network Or Click the Remove icon At the top (-)
WIRELESS SECURITY ISSUES - To Change the Security - Key
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
Sep 25, 2010 | Belkin N1 Vision Wireless Router
Tip
How to set up you wireless router to use a wireless network.
From a wired connection open you internet browser and type in 192.168.1.1 . The user name or password is usually "admin" or the password is sometimes blank. Once you log in you should change you network name from the default. For example a Linksys router's network name will be Linksys, this is fine unless someone else in you area has the same network name then neither of you will be able to connect.
To set up a wireless security you will need to select the type of security you want to use WPA or WEP and so. WPA is easier to remember as it is just a word you choose, while WEP generates a key based on a word you enter. If you do not set up a key you wireless network will be listed a unsecured.
If you set up a network key make sure to write it down, you will need it for every computer that wants to connect to your network.
If you are still not able to connect to the internet go back to the router menu via you internet brouser again. this time change the last letters of the default server. example 192.168.1.1 --> 192.168.1.4
on Feb 26, 2010 | Computers & Internet
I have secured my router by connecting my laptop to the router by ethernet cable so now my network comes up as security enabled but I can't seem to connect to my wireless network although it shows the...
Remove the neighbor's network from the preferred network list.
add your own network in the list. If your router is old router then upgrade the firmware of the router. Firmware is the software of the router.
You have connected your laptop to the router, to secure the wireless network. When you connect the laptop to the router, make sure that the wireless network connection will be disabled.
Once you change the wireless settings, enable the wireless connection and connect to your network.
Apr 25, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
My Router works only if I do not put security password on it.
The router works only if the network is unsecured.
When you secure the wireless network , make sure that you will change the wireless network name also. Because if you change the wireless security and if you keep the same network name then your computer will try to connect to the same network name with the old unsecured settings saved on the computer.
Try to change the SSID ( network name ) and security to WPA, check if that works.
If that doesn't work then I believe you will need to upgrade the FIRMWARE of the router.
Click here for more information about the routers and the wireless network
Jan 25, 2010 | Belkin Computers & Internet
I was running our wireless unsecure. I tried to
Some times the best thing to do is to use the reset button on your router and set it up fresh.
Oct 15, 2009 | Linksys Wireless-G Broadband Router
Unable to encrypt router
you have to check if you have the wep key enabled. when you put in the wep key, it should also be enabled so that your wireless network should say security-enabled wireless network. make sure to disconnect and connect again on your network after changing the settings to refresh your connection. hope this helps.
Jun 04, 2009 | Belkin (F5D5231-4) Router
Wireless router loses setup data
If the power lost power for at least an hour it loses its entire configuration. There is no current fix for this that I know of
May 03, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
How to get rid of old "unsecured" wireless network
SLRUSS63,
Are you referring to the Linksys SSID showing up when you browse for available wireless networks? Also, are you in an apartment building or otherwise relatively close to other houses/residents? It is possible that you and a neighbor both have Linksys APs and if neither was secured originally, your neighbor could have been connecting to your AP and vice versa. This definitely would explain slowness especially if you or your neighbor does any type of video or audio streaming.
One way to test this is to shutoff your Linksys router and view available wireless networks on your computer. If "Linksys" still shows up, it is most likely someone else's router/AP.
As long as your SSID shows up and you can only connect to it via the WEP key, your AP is secure.
Let me know if you get different results than I explained above.
Dave Grannas
Jan 23, 2009 | Linksys Cable/DSL 802.11n Security Rtr...
Wireless connection
You need to edit you're router's wireless settings, maybe there is a conflicting default network w/in you're range. Make sure you change the SSID (wireless name) to a unique name, the channel I advise you to set it to CH11, and enable wireless security as well, you can go for WPA-Personal it will be supported by XP and it's a good encryption method. And try removing all the network's listed on the "preferred networks list" on windows to make sure there won't be any conflicting wireless profile.
Aug 19, 2008 | D-Link DI 514 Wireless Router (DI-514)
Username & password
Changing the router password from admin to any password I think that you would be possible. Other brands of router has that option. And the router password won't affect the password for the wireless connection, they are different from each other. Wireless mac Filter is another way of securing your wireless network. Its done by listing the MAC Addrses (media Access control) or the physical address of your wireless adapter on your computer/s to either allow them to connect to the network or not to connect to the network. but I recommend to just use WPA security. It's secured and its much easier to add another wireless device to your network, because you just need to put the password and no need to get the MAC address and manually encode in on your router setup page. Its also possible to change the SSID or the name of your network.
I will get back to you with the steps on how to change the ssid adn change the router password. Okay?
May 26, 2008 | Zhone (6218-I2-200) Router
Dynex DXWEGRTR Router Logo
254 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
