Question about HP Business Notebook 6530b
No display on HP 6530b laptop
Lock A symbol is ON and flickering on HP 6530b laptop
No display
external monitor too does not help
5 Suggested Answers
  • 324 Answers
SOURCE: Dual (External) Monitors Hook Up for HP Pvillion zx5040us Notebook
Good day, Cyko!
Here is what microsoft has to say about that:
http://www.microsoft.com/windowsxp/using/setup/hwandprograms/monitors.mspx
In reading through this, you'll note that they suggest that some docking devices, or a usb adapter for monitors may allow you to run multiple monitors.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Posted on Nov 30, 2007
IB4G2008
  • 3587 Answers
SOURCE: Problem connection external monitor
check the seating of the monitor cable on the back of the hp laptop. sometimes that fit isn't so snug to work.
got backup?
Posted on Feb 12, 2008
  • 230 Answers
SOURCE: double display with my IBM think pad T43
have you tried Function F7/F8 ?
Make sure that your display driver is installed correctly.
I had the same Laptop as you did and was able to have dual monitor.
Also check your Display driver in your control panel and make sure it set to dual monitor.
Posted on May 12, 2008
chryssthina
  • 77 Answers
SOURCE: My HP 6530b laptop will not boot up, I get a blank
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
Posted on Apr 06, 2010
Blank stripe running top to bottom on screen. just started yesterday.
Sounds like a faulty screen. Check with an external monitor before purchasing and fitting a replacement screen.
Oct 30, 2015 | HP 6530b Notebook
Lock A and Lock 1 flashes at start up no display then shuts off
Let's go back in the diagnosis
You checked with an external monitor, to see that the graphics chipset was the problem, correct?
When using the Display Assembly from the 6530b on the 6730b, were you able to use the 6530b's Video Cable, to check it out also?
You are FOLLOWING Anti-Static Precautions?
How did the original problem come about?
Makes a difference.
Display just quit one day, or was there damage; such as dropping of the laptop?
Is the motherboard from a reputable dealer, or is it from a major auction house that starts with an E?
Post back in a Comment
Would appreciate all questions answered. I asked each one for a specific reason.
Regards,
joecoolvette
Mar 07, 2013 | HP Business Notebook 6530b
HP Pavillion with Vista won't display on external monitor.
Re-boot the laptop. Verify that the "POST" operation comes on during the restart - if not then you have a graphics issue in the laptop.
Feb 13, 2013 | Computers & Internet
Th problem is lcd
No display on laptop's internal monitor, and there is no blinking cursor?
Start with seeing if it is a display problem.
Connect a VGA monitor to the laptop. If the display does not show on the external VGA monitor, the problem is the graphics chipset.
You did not state the model number of the Fujitsu laptop, therefore all I can give is generic basic information.
1) Laptop OFF, monitor OFF, connect a VGA monitor to the laptop.
This is an example of a VGA Cable, and a VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
The VGA connector (Port) on your laptop is either on the side, or back of the laptop. May be marked on laptop as RGB.
You can use a CRT type of VGA monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
2) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
If not there are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and at the same time tap once on the Display Toggle-Over key.
The Display Toggle-Over key is one of the F keys at the top of your keyboard. F1 through F12.
It will have a monitor symbol on it.
(For example most HP laptops use the F4 key )
No display on external VGA monitor? Hold the Fn key down again, and tap once more on the Display Toggle-Over key.
If no display shows on the external VGA monitor you have a bad graphics chipset. Motherboard replacement.
If a display does show on the external VGA monitor, you have a problem with the Video Cable, and/or in the Display Assembly.
Post back with the results, after using an external VGA monitor, in a Comment.
Regards,
joecoolvette
Apr 25, 2012 | Fujitsu Siemens Computers & Internet
I bought a new Dell Pc and I keep getting flashes in the upper left hand corner. How do I get rid of this? Thanks
When you say flashes, is it like portion of the screen flickers?
If the flickering/flashes starts in Dell screen just right after turning on the laptop, when you see the Windows logo or just right after you log in to windows?
Try connecting your laptop to an external monitor then toggle display. To toggle the display to external monitor you can try holding down keys such as the function keys.
If the problem persist from the external monitor it means the problem is the motherboard or the video/graphics card.
If no problem from the external monitor this means laptop LCD and LCD cable needs to be replaced.
Hope this helps.
Jun 02, 2011 | Dell Computers & Internet
Ple help me my hp 6530b display flickring problum
do you see the same flickering problem in bios as well? if it is so then its a h/w fault. send the computer in for repair.
Apr 25, 2010 | HP 6530b Notebook
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
Connect broken laptop screen to external monitor
Suggestion- on my toshiba fn-f5 switches display modes, but to remove display connectors, you may have messed up your keyboard ribbon cable connection. it probably has a small sliding lock to hold it in place- if the lock isn't tight, your keyboard may not be recognized, which could mess up your display. Also, make sure your battery is charged and/or your power supply to your laptop is connected. hope this helps!
mothmanmeg@gmail.com
Sep 06, 2009 | HP Pavilion dv6000z Notebook
How to block VGA port on my laptop
in most cases, you can switch between display modes by using the function keys. the keys from F1 to F12 on your keyboard should contain various symbols (sometimes in blue). one of those symbols looks like the front of a monitor (on some laptops it says "LCD/CRT"). look for the key with the monitor symbol (or the text "LCD/CRT"), press and hold the Fn-key on the bottom line of your keyboard and then press the display mode function key. then you will see if the image on your display switch from one screen to the other.
if you cannot find such a key, you can disable the external display by right-clicking your desktop and choosing properties from the drop-down menu. on the "settings"-tab you should be able to see two virtual displays. click on display 2 and then uncheck the box that says "extend my windows desktop onto this monitor".
May 26, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Business Notebook 6530b Logo
588 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
