Question about Pool & Spa
I am working on a sta-rite pump model # p2rasf-182l - What seal do i need?
2 Suggested Answers
  • 83 Answers
SOURCE: Sta Right model P2RASF-182L (RPM 3450) sounds like
If the noise you are hearing is like a grinding, then the bearings are gone. Sta-Rite does not make the motors for their pumps, either AO Smith, or Centurian, makes them, so they recommend that you replace the motor with a new one. You can try a small motor repair shop in your area.
If it is an AO Smith motor, you may be able to find more information at the following website:
http://www.aosmithmotors.com/html/products/productLiterature.html
Posted on Jul 14, 2009
My sta rite pool pump motor is starting to squeal
motor is going bad probably overheating seals replace whole unit
Aug 08, 2012 | Sta Rite Pool & Spa
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have a P2RA5F-182L Sta-rite pool pump which the white plastic connector for the power leads has total been broken (it has the 220/110 switch integrated into it). Can i bypass this and straight wire it...
Contact me thru www.arrowmotor.net; we stock the part you need. To ensure you get the correct version it would be helpful if you took a digital picture so you can send it in an email.
To answer your question, yes - you could strip all the wires back and bypass the terminal board but in the long run it will make it much harder to install the part since you will need to put all new terminal ends on including a female pin style that requires a special crimper.
John
May 12, 2011 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
Procedure to change electric motor on sta rite pump
better off to replace whole pump if motor overheating seals going bad too if leaking soon bad bearings
Jan 16, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Where can a find a new pump CHEAP? Current pump is Model C48L2P104 (18 years old). Serial 1B93. Voltage 230 HP 1.5 RPM 3450/1725 Amps 9.2/2.5 Frame 48Y Dura-glas H/L
A new motor and pump parts (if needed) would be cheaper than a whole new pump. Your motor is part number UQS1152R or if you just want a single, high speed motor you could use USQ1152 to replace it. You will likely need a seal and seal insert as well; part number 100 (it may have letters in front like AS100, PS100, etc) and J3-2. A whole new pump you should shop for part #P2RA5YF-182L.
For a quote on the parts from us you can contact us using thru our website at www.arrowpools.net. Otherwise, google those numbers to locate your best deal.
John
Jan 04, 2011 | Sta Rite Sta - Rite Duraglas In - Ground...
Sta Right model P2RASF-182L (RPM 3450) sounds like the bearings are gone...turns on, but is very loud and gets very hot.  The water is not circulating either.
Jul 12, 2009 | Sta Rite Pool & Spa
Tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
May 28, 2009 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
Removing a staRite pump
a picture on how 2 remove sta rite , remember to prime the pump after any repair !.. the shaft seal used on this pump is a 100 or a 200 . i use pac seal mechanical shaft seals cost about 10$.. go kits are not required on 90 % of repairs $$
Apr 13, 2009 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
Pool & Spa Logo
57 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
