Question about Brother MFC-8840D All-In-One Laser Printer
Dark streaks on both sides of copy how do I clean this mfc ?
  • 215 Answers
I ama assuming this is an bro 8840d. if so, print one of your internal reports from the control panel. if streaks are there, then you probably need a drum unit. if internal reports look good, then lift the feeder on top of machine, and cleaned the little, narrow piece of glass to the left of your big glass.
hth,
razors
Posted on Jul 13, 2010
Brother 7220 black streaks
Clean the roller and the inside of the machine, asny residue on the roller will cause these black streaks. If cleaning doesn't cure the problem you will need to replace it.
Jan 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
MFC8500 VERY DARK STREAK (.25 INCH WIDE) RUNNING DOWN THE ENTIRE WIDTH IOF THE PAGE.
Reference page 22-17 in reguards to cleaning the charge wire on the drum unit and page 22-16 for cleaning the document scanner. This is a link to your Brother MFC 8500. Hope this helps.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8500_EN_1354.PDF
If the dark streak appears on printed documents, cleaning the charge wire will correct it.
Nov 04, 2009 | Brother MFC 8500 All-In-One Laser Printer
The receiver states that our faxes that we send are unreadable down the right side of the paper--white or dark streak. The faxes we receive are ok
The glass scanner window (narrow strip of glass) needs cleaning. One "spot" of dirt will appear as a streak on the receiving end.
If you "copy" a document you can check the streak and see how effective your cleaning is.
Sep 28, 2009 | Brother IntelliFax-2820 Laser Fax
I have a BROTHER MFC- 8860DN that makes black streaks on copies
If this is only happening with copies and not straight prints, it is possible that the problem is with the scanning unit. Use the soft cloth to clean the scanner area to the left side of the machine where pages are scanned when run through the page feeder. A spec of dust or other debris in this area will appear as a streak along the length of the page.
If it occurs on all prints, You may need to replace the drum or clean the fuser unit.
May 29, 2009 | Brother MFC-8860DN All-In-One Laser...
ADF copy with black streaks?
lift up your adf and locate the thin piece of glass, about an 1' wide, and clean real good with rag and windex. probably white out or some foreign material on that glass.
hth,
razors
Feb 27, 2009 | Brother MultiFunction Center MFC-440CN...
Faxing and or copying a black streak developes, answer??
Open up the document feeder by pulling up and clean the scanner glass
Jan 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Printing is streaking
What exactly did you clean on this machine? Also, when you say it streaks, is it when you're printing or making a copy?
Jun 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8840D All-In-One Laser Printer Logo
138 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
