Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
How do change the light bulb in my Kenmore Elite refrigerator?
SOURCE: Kenmore refrigerator light does not work
i am having a problem with my ref..it functions okay, but theres no light when i am open the ref.. before it does... whats wrong with it??? anyone help me what to do???
Posted on Jun 12, 2008
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
Sea Breeze
  • 4654 Answers
SOURCE: My kenmore Elite Trio lights didn't go off, it
This will possibly fall in the class of models that were under recall. My advice is to contact Sears and the CONSUMER ALERT Remove your lighyt bulbs and prepare for a disgusting attempt for settling this. I am not telling you you this for any good rate or a bad rate. LG and Maytag made these for Sears and the name then changed to Kenmore Elite Trio. I would like you to visit my web page and do a little reading of our posting's here at Fixya over the past couple years. Wish I had a solution but feel it is my responsibility to inform you. Thank You for Understanding, Sea Breeze
Click Here=> APPLIANCE CONSUMER ALERT
Posted on Nov 07, 2009
arikrom
  • 528 Answers
SOURCE: Kenmore Elite refrigerator not cooling
no no put it back to normal setting!!! now is the freezer side cold? if it is cold you need to open it give me your model # and i help you arikrom@gmail.com
Posted on Dec 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: kenmore elite refrigerator freezer won't close tight.
Head over to the manufacture's website. www.searspartsdirect.com
Enter your full model number in, and you can see expanded diagrams and part ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
How to change light bulb in Kenmore refrigerator serial no. 4A31214613 ?
Open freezer and reach to the back of the plastic cover over the light. You'll feel a gap in the back center of the cover. Gently pull forward and the cover will drop down and pull to the back to fully remove it. Once you've removed the cover you can unscrew the bulb, which you can use to make sure you purchase one like it and most hardware stores, such as Ace or Home Depot. Reverse the removal instructions to install light and cover. Light should turn on once you've screwed it in.
Jul 22, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
How do I change the light bulb? I twist and pull but nothing happens. I have a Kenmore 106.72864100.
Is it the cover or the light bulb that isn't coming out? The cover for the 74889 needs to be pushed up and then pull it forward and down. It is hanging by a tab that holds until the angle of the cover is changed to a shallow angle relative to the back of the fridge. The light bulb should unscrew by turning it counterclockwise. If the bulb was previously overtightend, then you may need to use something to improve your grip on the bulb. I sometimes use the plastic jar opener sheets. If the bulb breaks, remove the remainder of the bulb from the socket with pliers (I use needle-nose or similar long straight blade pliers held open to the width of the butlb).
You should unplug the appliance while changing the bulb.
The manual for the Kenmore 74889 is available here: http://www.managemylife.com/mmh/owner_manuals/5899/KENMORE-Top-Mount-Refrigerator-L0411041?brand_name_search=Kenmore+74889 . Other Kenmore manuals can be found by using the search engine here: http://www.managemylife.com/mmh/owner_manuals .
I hope this helps.
Mar 21, 2011 | Kenmore 74889 / 74882 / 74884 Top Freezer...
The lights will not go out on our kenmore elite 22.4 cu. ft. ref.
The door switch is bad, replace yourself easily. meanwhile unscrew bulb.
Nov 01, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hi. The bottom freezer light won't turn on. I checked the bulb by putting it in another appliance an it wordked. What gives?
We have the same issue with the 22.4 Cu Ft Kenmore elite bottom freezer. Has anyone figured out the problem? Very frustrating..We have unplugged the fridge..nothing. checked to make sure it was getting power to the light socket..all good. We accidently left the freezer door open a little. maybe 15 minutes..we looked and the freezer light came on..closed the door and opened it again, the light still came on..got up the next morning and no light again..Sure dont want to spend $75.00 for a sears tech to come look at it...
Oct 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Light in freezer does not work. Tried new bulb without success. Thanks.
its likley to be the light switch in the door not working right,,,,have a look at that as well
Jun 08, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My kenmore Elite Trio lights didn't go off, it burned the light assembly in the refrigerator part. The bulbs turned dark and it melted the assembly a bit, the cover won't stay on. can I install a whole...
Nov 07, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Light bulb stays on in Kenmore Elite fridge Model # 795.77559600
I had the same problem with a kenmore elite fridge and recieved the same response from Sears customer service!!! File a complaint with your local BBB. Sears contacted me within the day and sending out a tech at their expense only after the complaint was filed. Good luck. Elana
Jul 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
709 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
