Question about Samsung L200 Digital Camera
The lens would not open after powering on
Despite the camera being fully charged
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 05, 2010
My camera lenes wont stay open
Usually the lens closing is a sign that the battery is dying. If there's not much power left for the camera, it will first close the lens so it's protected before powering down. Make sure you have fresh batteries, fully charged. If the battery is going bad it may not hold a charge for very long but appear to be charged when you first intall it.
Dec 25, 2014 | Kodak EASYSHARE M340 Digital Camera
Mistake on last post - my brand new Canon EOS6D won't power on, despite fully charged battery.
Since it is a brand new camera, take it back to the shop where you bought it. There isn't really anything you can do.
Sep 19, 2013 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
The camera starts up and shows the blue sanyo screen. Then the screen turns black then shuts off. The lens doesn't even open. I've tried charging the battery and that is not the problem. What's...
Hello ..Yes please make sure your batteries are fully charged..If battery is charged and still shuts down..There is a good chance lens was hit or bumped.When lenses are bumped the camera will try to extend lens upon power up as part of cycle.If camera detect problem with lens not opening..Then it will shut down...
Sep 23, 2011 | Cameras
Olympus X-920 camera lens fails to fully open when powering on, the lens cover does open for a few seconds, then the lens retracts and opens again every few seconds. The Battery appears to be fully...
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jul 02, 2011 | Olympus X920 Digital Camera
My Canon Digital IXUS 960 IS camera will not turn on despite having the battery fully charged. What is wrong with it?
Is the battery powerfull enough? Meaning has enough DC current in it to powerup? There are 2 "ON" buttons one at which the lens comes out, the second to view pictures.
Jun 28, 2011 | Canon IXUS 960 IS Digital Camera
MY CAMERA LENS OPEN CLOSE E READY ACSESS NO
so i charged my battery, and same thing happends. Bought a new battery, didnt chatge it fully, but had one charge bar on it and the same thing is going on??????? ANy suggestions
Jan 14, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Cameera lens will not open (expand) when turned on.
Please check whether you're using a fully charged battery.
After fully charging the battery if the issue still persists, please try Power Resetting the Camera.
To Power Reset the Camera.
First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cameras
Lens stuck halfway open
Fully charge the battery or connect the camera to the power supply (if you have an ac adaptor).
If it still does not work, it means that the lens is broken.
Reason can be that the camera was in your pocket pr carrying bag and the camera inadvertantly open and the lens mechanism was damaged. In this case, it needs repair.
Apr 21, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
LENS DOESN'T OPEN
The following blog outlines some repair options for a lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
By the way, try Fix #1 first with different fresh batteries.
Dec 10, 2007 | Olympus FE-230 Digital Camera
Samsung L200 Digital Camera Logo
281 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
