Question about Philips 42PFL5603D - 42 IN. LCD HDTV
Hi I need a new infrared sensor for my TV, I'm struggling to find the part number could you help
    Problem Solver:
  • 5 Answers
Assuming it is an infra-red sensor with 3 legs, or 3 legs and 2 other legs as stands, you should be able to use any old 3 leg IR sensor.
If it s a 2 leg one, any other generic 2 leg IR recieve diode will do. With either type, you just need to get the device back in with the same leg configuration. it is usually marked on the circuit board
Posted on Jul 05, 2010
Help I have an Emerson standard TV model number ewt2721 and the remote sensor is not working. I have direct TV so I need to put the TV on game mode to have the picture. Also would like to use my DVD. Is...
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
May 30, 2014 | Televison & Video
If the remote sensor inside the tv stops working...is there something i can get....a box or something to change channels with another device..some tv cable can go thru before to tv so if tv is on a certain...
Check your remote control for its proper working first. Then think of the remote sensor inside your TV. To get more details about how to check remote control, click this link.
If remote control is Ok, replace the infrared sensor, which can be located just behind the infrared sensor window of your Tv. You have to open your TV, and desolder it out and solder a new one in position. The infrared sensor will look like these. There are sevieral types, and just confirm which type is used in your TV. Picures of some types are attached.
6_14_2012_6_34_32_am.jpg6_14_2012_6_35_11_am.jpg6_14_2012_6_35_33_am.jpg6_14_2012_6_35_53_am.jpg6_14_2012_6_36_17_am.jpg
Jun 13, 2012 | Samsung TV Set Top Box Remote Control
Tv doesn't pick up signal from remote
Hi Connie,
First of all, thank you for posting your question here at Fixya.
Please ensure that the battery is in good condition. Check the battery terminal for corrosion, Scratch it with fine sandpaper.
If the battery and its terminal is not the issue, please confirm if the remote control emits an infrared by pointing directly the sensor (infrared emitter) to your cellphone/digital camera. If it is working fine, you will be able to see the flash of the infrared through the screen of your camera. Watch the video below.
If you've confirmed that there's no infrared coming out from the remote control then this is an indication that the remote control itself is already faulty. Replace it with new one (part no. 0980-0305-3300 ).
If you can see the flash of the infrared, the IR board inside the TV is faulty. Please inquire at this link for replacement.
Hope I helped you.
Good luck and have a great day!
Jdvillanueva
Jan 11, 2012 | Vizio VL420M 42 in. HDTV
Remote to tv doesn't work
Hello
Check the remote first for its infrared emission. If it is OK, the infrared sensor inside your tV is faulty. It should be replaced with same type and number. It can be located just behind the infrared window at the front panel of your Tv. You ahve to open your TV ot access it. It will have three solder terminals, and will look somehat brownish black in colour. Will look like this.
Nov 14, 2011 | Televison & Video
Tv remote not working
Hello
Check the remote control for its infrared emission first. You can check it with the help of a cellphone with camera. Eventhough human eye cannot detect infrared rays, electronic cameras can. Put your cellphone to camera mode, place the remote control [ replace its batteries with new ones]; at about one feet away from the camera lens, and press each button on the remote control. If infrared emission is there, you can see its image on the cellphome camera screen. If there is infrared emission for all button press of remote control; the infrared sensor inside your TV is faulty. It should be replaced with same type and number. If there is no infrared images, the remote control is not working, and should be replaced. Check the battery contacts of the remote battery compartment for any rust or dirt. Clean it well before replacing new batteries into it. OK.
Jul 06, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Hi Expert, Both remote control did not work. The original came with TV and the Cable remote control. Thanks
Hello
If both remotes are not working with your tV, the infrared sensor inside your TV is faulty. It should be replaced with same type andnumber. Infrared sensor can be located just behind the infrared window on the front of your TV. It will be soldered direltly to a board, and can be detacted out from it. You have to open your TV, and locate this component. It will be in bronish black in colour and will have three solder terminals. The number will be printed on its body, either by ink or by laser print. Note the number, and it iis very inportant when you repalce it. OK.
Jun 24, 2011 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
How do you instal the ir reader in the tv...it is not reading the remote
Hello
The component you describes here is not the reader, it is calle the infrared sensor. It is three terminal component, can be located just behind the infrared sensor window of the set at its front panel. It will be soldered direltly to a panel board inside. To access it, you have to open the TV, locate the position of infrared window and there will be it. Just unscrew the board along with it, desolder it out from the board and go for a new one with the detached one as sample. It has a special number printed on it [laser printed]; and should be noted. Insist on same type and number, since it is a crtical component in your TV, although it is very small in size. It will look somthing browinish-black in colour, and can be bought from most of the electronics spareparts shops at your town. OK
May 14, 2011 | Philips 32PFL5403 LCD TV
My remote will not work the tv anymore
there are three possible causes for this problem;
1. Batteries may be dead inside the remote.
2. Remote might be defctive.
3. TV remote sensor/infrared might be defective.
Battries; Simply insert new batteries into the remote and try again. If changing batterises doesn't help, problem as to be from the Remote or TV's infrared.
Remote: Check the remote battery terminal, see if its not rust. Also, disassemble the remote, can check the connection between the terminal and the remote board, see if there is no disconnection of any kind.
If after checking and all seems well, then it means the remote is defective. To confirm, borrow a remote, test it with the TV. If it works, then it means you need to replace your remote. But if the remote you borrowed does not work, then it means the problem is from the TV and not the remote.
TV: There is a sensor in the TV that communicates with the remote. If this sensor is defective, the remote won't communicate with the TV.
The TV sensor might have loosed contact from inside of the TV or it maybe defective and need to be replaced.
So do the above troubleshooting and let me know if the problem is from the TV or remote. If problem is from the remote, you need to do a replacement. But if otherwise, let me knows as well.
Yours sincerely
Elect_Comp.
May 12, 2011 | Televison & Video
I have a sony Bravia KLV-S40A10E 4 years old.Remote controle device is no ore working. Batteries have been changed without solving the problem .. Other Remote device ( DVD-Sony ) is also not working...
Hello
You just check your remote control handset for its infrared emission. There is an infrared light emitting diode [LED], in front of your remote control handset from which infrared light rays are send to your TVs infrared sensor, fitted inside it, behind the infrared window on its front panel. Infrared rays are invisible to human eye. We can check if it is there by using a cellphone with camera option.
Put the cellphone in camera mode, and place your remote control's LED side towards its lens, for about a feet away or so, and when you push its each button, you can see an image in the phones' screen. If it is there, and still your TV don't work with remote control, TVs infrared sensor inside is faulty, and needs replacement.
If there is no infrared image from your remote control, you have to buy one new remote control. OK.
Dec 18, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Remote not working
Hello
You just check whether the remote control has infrared light emission from it or not. It can't be see with our eye, as infrared rays are invisible to us. Put new cells in the remote handset before you proceed. If you have a cellphone with camera option, the things are easy. Put the cellphone on camera mode, and place your remote control just in front of its lens, at about one feet away or so, press each button on your remote handset, The camera will sense the infrared radiation, and you can see its image on its screen. If there is infrared radiation sign, and still your TV doesn't respond to it, your TVs infrared sensor inside it is faulty. It comes just behind the infrared window ath the front panel of your Tv. It is a three terminal component, and can be resoldered out of the board, and can be replaced. Open your TV, locate it and resolder it from the board. go with that as a sample, and buy a new one with same type and number. its number will be printed [laser markling], on its boady, and should insist on it,a s it is a critical part. Replaceing it will solve your problem. Ok
Dec 16, 2010 | RCA F36673ET 36" TV
Philips 42PFL5603D - 42 IN. LCD HDTV Logo
362 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
