Pilot light does not go on have a vulcan bonaire system and on control panel it does not switch to heater
    President:
  • 1,561 Answers
Have you check the outlet you plug it into, if it has power, if it does, try see if there is curreny entering the unit, if current is entering, check the fuse on the unit to ensure the fuse is not blown, if it is replace the fuse.
I would like you to know that, this unit requires regular service from time to time to keep the unit functioning properly, if it has been long you service the device, please service it because this can also cause the problem.
Take care.
Posted on Jul 05, 2010
Bonaire vulcan comfort control
No it cant really be fitted as the evap system uses much larger duct and also in some cases people use a different type of duct that when running a gas heater threw it it tends to melt with the heat. Your best option would be to get new ducting that way you can size it correctly so you dont have air alance issues down the track.
May 10, 2014 | Heating & Cooling
How do you change the zoned sections on the control panel/remote
you need to do the programming of the Zones with in the first 5 min after powering up tghe unit threw the wall controller
Apr 27, 2014 | Heating & Cooling
Vulcan climate control gas heater starts uo and does not stay alight after several attempts controls show reset mode have tried switching on and off does not work
There is a troubleshooting (problem solver) guide in the manual... you can see it here.....its the last page.
http://www.bonaire.com.au/lib/pdf/owners/mf228.pdf
If everything there chacks out then look for the thermocouple. I looked around and did not see one for the Vulcan heater. I would call then directly to find a dealer and a part number fo it.
Heatman101
Mar 09, 2010 | Heating & Cooling
VULCAN BONAIRE Users manual.
Try here http://www.bonaire.com.au/support/documentation/owner/default.aspx
Dec 31, 2009 | Heating & Cooling
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
Control panel lights constantly flashing
You should have a dedicated line that feeds the equipment power look at your main electrical panel or search around your equipment for a pull out disconnect switch or sometimes they will wire it to a light switch. by shutting down the main power and turning it back on it should reset anything.
Jan 04, 2009 | Mastercool 67471 Evaporative Cooler Air...
Heating & Cooling Logo
26 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
