Question about Pool & Spa
Dayton mfg time switch for pool pump no info on the switch, model no or anything other than mfg. 240 V to a GFI to a throw switsh to the pump motor.Switch is 5 pole (A,1,2,3,4) How do I wire this properly I know the switch needs 240V the GFI gets 120 from the switch , the throw switch gets 240 to send to the pump to run. Too many poles n wires to do trial and error as components are not cheap and I fear frying things thataren't in the frying pan.Can anybody help a rapidly balding guy out? MIama n babies gotta swim and if they soon don't I will most likely never have to pay for a haircut again
  • 990 Answers
I don't know about your GFI, but it probally wires off one of the hot leads.
As for the others two come in (line) and two go out (load) The two that come in will hook to the two leads that have seperate leads running to the clock motor as this needs power all the time. These are probally small wires that come off the main terminals and go behind the clock wich is where you will find the clock motor.
The leads going to the pool motor will hook to the other two terminals.
Your last terminal is probally a ground.
If you take the gut to a pool store they can probally match it. Home Depot or the like will have to many other types to match.
The new one will have instructions and a sticker for your door on the clock for future reference.
Hope this helps, good luck.
Posted on Jul 05, 2010
Testimonial: "this helps loads(no pun intended)I thank you very much and will let you know the outcome"
  • Kieran Ruppert Jul 07, 2010
    It's good to be punny.
    Glad to help.
I have a 220 volt gfi breaker tripping its new install how does the gfi wire up
The bi-metal motor overheat protection switch is internal and it is activating probably with or without the ground fault interrupt they prevent electrocution and other devastation, do not modify anything. Do not hesitate, seek a very experienced pool electrician, NOW.
Jun 01, 2015 | Century B2859 2 HP Centurion 230/115 Volt...
How do I use the timer
well you didnt say anything about model or mfg you got but most timers older than 5 yrs old set with little plastic pins red for on black for off , most newer ones set directly by digital time shown on display using up/down key to change time
Sep 27, 2014 | Pool & Spa
I have a Dayton 5X848N relay switch that needs connected to a well pump. how is it wired
go to www.ehow.com and type in the search box
"relay switch wiring"
and you will pull up 6 web pages of click on the post articles
on how to wire in a relay. somewheres in all that techinical info
someone will be writing about a relay just like yours & be giving step by step instruction as well as tools needed to do job.
try typing in search box---" how to wire dayton 5x848n relay into well pump.
You should also have the make and model of the well pump handy on paper as you will need this to find out where relay goes to pump motor.
If you need more specific info type in search box
*how 2 wire dayton 5x848n relay into make & model well pump*
try that on google.com.;bing.com;ask.com;yahoo.com as well as
ehow.com
they all have search box on upper right coner of web page & they all answer questions with pre writen info.
Oct 12, 2013 | Dayton Dryers
Need to change a goulds 1.5hp motor from 120 to 240 volts
should have info on side of motor, some motors cant be switched
Mar 19, 2013 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
How do i wire a ge mechanical time switch 15306 to a pool pump
Get an electrician to do this. You don't want shock anyone in the pool!
Jun 06, 2012 | General Electric Mechanical Timer, 120...
Wiring two 240 v loads to a switch
threw a intermatic t104 timer, hook the salt gen. to the same side as the motor .. you should have a timer already on the house for the pol pump ? use it the same way .. Jay the pool pump motor repair guy longwood Fl
Apr 06, 2012 | Hayward Pool & Spa
Where do i connect load wires to 240 volt baseboard heater
240 load goes to 240 supply if on all the time
or 240 load goes to one leg of switch other leg goes to supply
Oct 27, 2009 | Dayton G73 Utility Heater
Rule H53sp-24 pool cover pump trips GFI breaker
GFI devices are prone to degrade over time. Also, when used outdoors there are additional moisture issues that may cause sufficient current leakage to trip the breaker.
I had a similar problem this Spring. I was using a 20 amp GFI "master" outlet that protected two additional outlets 'downstream' of it (wired to the 'load' terminals on the GFI outlet- I'd have the check the doc. to see what terminology was used here). The pump was plugged into one of the downstream outlets.
Replacing the GFI seemed to solve the problem. I did ante up $20 for an 'outdoor' model of the 20 amp GFI unit, several bucks more than the standard 'indoor' unit - have no ideal if that represented additional value or not.
Note also, that this is the third such pump I have used for my pool cover. The other two failed to come on at all after about a year's use. The mfg replaced them under warranty (I may have had to send back the old pump - I forget!).
Curtis
Mar 22, 2009 | Rule H53sp 24mgra Swimming Pool Cover Pump...
Pool & Spa Logo
191 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
