I have to change A ribbon on my victor 1240-3A . Is there A way to do this without getting the ribbons caught in the gears.?
  • 186 Answers
SOURCE: The ribbon is no longer printing on the tape.
are you sure it uses a ribbon? Or does it use an ink roller. If it uses a ribbon it should reverse by it self. Make sure it is installed properly, there is not a ribbon reverse switch it should do it automatically. if its installed right.
Posted on Jun 17, 2007
  • 99 Answers
SOURCE: RIBBON CHANGE
Make sure the ribbon is facing the correct side. Usually, there is a small encave which is to be facing downwards. Snap it in place and you are good to go.
Zabrina
Posted on Feb 07, 2008
SOURCE: Changed Ribbon
I bought the ribbon and it did not work so I took it back got another
one and it still will not type
Please help
Posted on Sep 23, 2008
  • 6 Answers
SOURCE: ink ribbon
It takes a CP-13 ink roller. The cheapest I could find was a 5 roll set online at the Canon store. It is $16 wth a $5.99 shipping and handling charge. They also charge sales tax. The rollers can be bought at many places including ebay. It's removed by pulling up on the right hand little tab part. The new one should snap right in. Be careful not to touch the ink section. The roller is the same for any P23-DH machine it doesn't matter what Roman numeral one you have.
Posted on Oct 21, 2008
SOURCE: how do I change the ribbon on my casio hr-8tm calculator?
Place the roll on the wire thing at the back (I don't think it matters which way round); push the paper through the slot at the bottom of the back and then (having taken the clear plastic cover off) push it along the bottom inside at the back as far as you can then start to press the feed button; keep feeding it with your finger and pushing the feed button asnd it should pick up eventually.
Posted on Feb 23, 2009
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
The red ink no longer is visible, what can I do
I can't give you a definitive solution without knowing the model of your calculator, but my first inclination is to suggest you replace the ribbon or whatever the calculator uses for an ink source.
Sep 24, 2013 | Victor Office Equipment & Supplies
I changed the ribbon to the monochrome R3012, but the printer has the NO RIBBON light on and it won't recognize it. I set the printing references to that ribbon style, the ribbon is not torn, I have made...
You may have installed ribbon incorrectly.
Align the gears of ribbon spindle with gears on printer and second important thing is that ribbon should come from up not from down.
Mar 13, 2011 | Evolis PEBBLE 4 Led Card Printer
Changed the typewriter ribbon because it snapped in two. At first the typewriter would not do anything and was beeping and the "store", 1 1/2 and 3 lights were on. I oiled the carriage as...
do you have a printwheel in this machine (round grey disk with "fingers" evenly spaced around it with the charachters on it)? If not - there's your problem. you can repair the ribbon with a small piece of tape (no wider than the ribbon. stuck to the backside (shiny) of the ribbon then turn the ribbon until the taped part goes into the cartridge a ways. if the ribbon is moving ok and you still have a printwheel installed, make sure the ribbon is not getting caught in the printwheel.
Dec 20, 2010 | Nakajima AX-150 Typewriter
Printing is very faint. How to change or add ink printer device.
This is most likely a ribbon impact system. Any office supply store should have the ribbon you need, with information on compaitability on the package.
Remove the paper roll and gently but firmly pry on the bezel surrounding the paper exit path. Examine the sides of the ribbon casing for any clips or fasteners.
May 22, 2009 | Victor 1280-5 Calculator
How to say to the priter we donĀ“t use ribbon
If you are printing in direct thermal mode (without a ribbon):
· Check your software settings and make sure that the print type is 'direct thermal'. If your software package requires the use of a Windows driver, also make sure that the driver is set for direct thermal printing.
If you are printing in thermal transfer mode (with a ribbon):
· Check your software settings and make sure that the print type is 'thermal transfer'. If your software package requires the use of a Windows driver, also make sure that the driver is set for thermal
transfer printing.
Check to see if there is any dirt on the ribbon spindle gears or on the ribbon motors. For the latter
you will need to remove the electronics cover. If there is dirt in either of these areas, try vacuuming around the motors and/or the spindles to remove as much of the dirt as possible.
Mar 17, 2008 | Toshiba TEC B-472 Thermal Label Printer
Wheelwriter 30 Series 2
First off make sure the ribbon turns freely.Take off the ribbon and turn the ribbon wheel in the direction of the arrow and see if it turns smoothly. If it turns smoothly the ribbon motor is not moving or the gear is not moving. take off the ribbon and type. See if the black ribbon drive gear on the ribbon deck moves as you type. If not the motor is N.G. or the ribbon gear clutch spring is not grabbing the gear to turn it. Lawrence
Feb 14, 2008 | IBM Wheelwriter 30 Typewriter
Keys locked and machines beeps
Try reinstalling the ribbon again. Sometimes the ribbon get caught in the daisywheel. If that doesn't work, try a new ribbon.
Jim K.
Nov 27, 2007 | Office Equipment & Supplies
Hot to change ribbon on sony m8800
Its not too hard to change. I have done this once before. Open main unit. Remove cd mech to get to the other end of the ribbon. Remove this end first. Manually rotate the motor worm gear until screws on head unit are visible. Install ribbon in head unit then main unit. Make sure the ribbon contacts and ribbon are positioned/routed the same way. Rotate that motor (end to end) again to see if the ribbon hangs up anywhere.
Nov 05, 2007 | Sony CDX-M8800 CD Player
195 people viewed this question
k24674
jasbo
jasbo
