HITACHI WASHING MACHINE MODEL SF-60. THE MACHINE GOES THROUGH THE CYCLE TILL THE SPIN THEN ON OFF SWITCH BUTTON POPS OUT,IF YOU THEN SET IT UP ON SPIN ONLY IT DOES WHAT IT IS SUPPOSED TO. ALL MOTORS WILL WORK OK.
I have also the same problem for sf 60..any one can help?
Posted on Oct 29, 2013
HI,
MY MACHINES MODEL IS KW-D502-HITACHI,
MY QUESTION IS ,HOW TO USE PERFECT?
Posted on Aug 06, 2008
  • POYA_SHO Aug 06, 2008
    I DONT HAVE A CATALOG,AND I CANT FIND IT.PLZ HELP ME.THANKS ALL
Hitachi sf-6500px error
Possible error on the program due to a memory issue. After resetting, if the machine has the same fault with all the selected programs, then it is possible that the motherboard is faulty. Please check the INLET flow to be good and the drain pump to be clear.
Jun 25, 2013 | Washing Machines
My washing machine hitachi make model no SF-70EJ having problem with spin please give assistance what to do
Hi.
Most spin problems are consequence of drain system faults.
The first part to check is drain system. Check the drain hose at the back and the drain filter attached to the pump. See article at the end for more detail.
Most machines' timer boards do an additional check on the lid switch before starting the spin part of the cycle. If the lid lock light is flashing and the machine does not spin the lid switch is probably defective.
The lid switch is tested jumping its contacts or reading Ohms at switch terminal. A two-terminals switch must read continuity (low impedance) when door is closed and must read open (infinity of Ohms) when door is open. If the switch is a three contacts, the third contact is called "heater". In that case there must be continuity between the three contacts with lid closed. If the model instead of a simple switch uses a wax motor, then the lock cannot be tested by jumping contacts. The lock motor must be tested reading Ohms and checking that impedance is the same as indicated in service manual.
If lid switch and drain system are OK, then the pressure switch must be tested.The pressure switch detects the water level and among other things determines when to advance the cycle to spin.
If all the above is OK, then the motor and motor control unit (if present) must be tested.
Please read the solution in the article below for more:
If you have no spin ...
You can find parts and diagrams for most appliances using the links listed on this page: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 04, 2011 | Washing Machines
Hitachi washing machine SF-80FJ error C1 on LED
my hitachi model SF-80 FJ is washing machine cleck c2 warning stop Kwongboonsin@yahoo.com Bangkok 10330
Feb 05, 2011 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
Hoover 1300 washing machine
hi there this is a common fault you will need to replace the control module and selector switch/timer
Dec 01, 2007 | Hoover H130E Front Load Washer
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Washing Machines Logo
395 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
